picbasic +12c508a+soft_stack error
Results 1 to 37 of 37
    Dec 2007
    Default picbasic +12c508a+soft_stack error
    Hi
    I wrote a simple basic program for my PIC (12c508A) in a Picbasic Pro compiler
    but I have this error after compilation "unable to fit variable soft_stack"
    please see my program below and tell me the errors as I am beginner in PIC programming .
    lowinput VAR GPIO.0
    overtemprature VAR GPIO.1
    overload VAR GPIO.2
    outputpin VAR GPIO.3
    green VAR GPIO.4
    red VAR GPIO.5
    count1 var byte
    i var byte
    OUTPUT outputpin
    input lowinput
    input overtemprature
    input overload
    OUTPUT green
    OUTPUT red
    while i=0
    if (lowinput=0) and (overload=0) and (overtemprature=0) then
    outputpin =0
    High green
    Pause 500
    Low green
    Pause 500
    if (lowinput=0) and (overload=1) and (overtemprature=0) then
    while count1<2
    gosub overloadmode
    count1=count1+1
    wend
    outputpin =1
    while count1<7
    gosub overloadmode
    count1=count1+1
    wend
    outputpin =0
    count1=0
    if (lowinput=1) and (overload=0) and (overtemprature=0) then
    while count1<5
    gosub lowinputmode
    count1=count1+1
    wend
    outputpin =1
    count1=0
    if (lowinput=0) and (overload=0) and (overtemprature=1) then
    while count1<5
    gosub overtempraturemode
    count1=count1+1
    wend
    outputpin =1
    count1=0
    if (lowinput=1) and (overload=1) and (overtemprature=0) then
    while count1<5
    count1=count1+1
    wend
    outputpin =1
    count1=0
    wend
    overloadmode:
    High green
    low red
    Pause 500
    Low green
    high red
    Pause 500
    lowinputmode:
    High green
    low red
    Pause 500
    Low green
    high red
    Pause 500
    overtempraturemode:
    High green
    high red
    Pause 500
    Low green
    low red
    Pause 500
    you may need to move on a bigger RAM PIC such as PIC12C509. 12C508 have 25 bytes of RAM, while 12C509 have 41 + twice the program space size.
    The compiler use between 20 & 22 bytes of RAM itself.. so... no real space for more variables
    A 12F might be a good choice. Cheaper too.
    However, what you have should fit, with a little modification.
    The complex IF statements are creating 3 (T)emp vars, which are word sized. (even though it's only using 1 bit per WORD)
    So it's using 6 bytes that it doesn't really need too.
    If you change all the IF statements to something like this for the first one, I believe it should fit.
        ;if (lowinput=0) and (overload=1) and (overtemprature=0) then
        if (lowinput=0) THEN
            if (overload=1) THEN
                if (overtemprature=0) THEN
                    while count1<2
                    gosub overloadmode
                    count1=count1+1
                    wend
                    outputpin =1
                    while count1<7
                    gosub overloadmode
                    count1=count1+1
                    wend
                    outputpin =0
                    count1=0
    hth,
    i was thinking of a select case and GPIO mask. mmm...
    edit: Seems to work
    lowinput VAR GPIO.0
    overload VAR GPIO.2
    green VAR GPIO.4
    red VAR GPIO.5
    count1 var byte
    Mask var byte
    OUTPUT outputpin
    input lowinput
    input overload
    OUTPUT green
    OUTPUT red
    Start:
            mask=GPIO & 7
            select case mask
                    case %000 ;if (lowinput=0) and (overload=0) and (overtemprature=0) then
                        outputpin =0
                        High green
                        Pause 500
                        Low green
                        Pause 500
                    case %100 ;if (lowinput=0) and (overload=1) and (overtemprature=0) then
                        while count1<2
                            gosub overloadmode
                            count1=count1+1
                            wend
                        outputpin =1
                        while count1<7
                            gosub overloadmode
                            count1=count1+1
                            wend
                        outputpin =0
                        count1=0
                    case %001 ;if (lowinput=1) and (overload=0) and (overtemprature=0) then
                        while count1<5
                            gosub lowinputmode
                            count1=count1+1
                            wend
                        outputpin =1
                        count1=0
                    case %010 ;if (lowinput=0) and (overload=0) and (overtemprature=1) then
                        while count1<5
                            count1=count1+1
                            wend
                        outputpin =1
                        count1=0
                    case %101 ;if (lowinput=1) and (overload=1) and (overtemprature=0) then
                        while count1<5
                            count1=count1+1
                            wend
                        outputpin =1
                        count1=0
                    end select
            goto Start
    overloadmode:
            High green
            low red
            Pause 500
            Low green
            high red
            Pause 500
    lowinputmode:
            High green
            low red
            Pause 500
            Low green
            high red
            Pause 500
    overtempraturemode:
            High green
            high red
            Pause 500
            Low green
            low red
            Pause 500
    Hello Mister_E
    Could you please explain? This statement appears to me to mean PIC BASIC PRO is an intrepreted code, if not why would the compiler require any of the PIC's ram?
    Thank You
    JS
    Yeah but the library/compiler need to reserve some variable to work to not interfer with your code... euh.. that's my understanding
    support for 12 bit core is limited, and the real explanation can be found at the bottom of the folowiing page
    http://www.melabs.com/support/12-bit.htm
    so why 20-22... i don't know, seems hungry to me.. but, you have to deal with it.
    We already heard something like that for 10F and bring some weird/nasty/dangerous/clever alternate solutions, some who remind...
    http://www.picbasic.co.uk/forum/showthread.php?t=4789&
    HTH
    After converting all the IF statements like I suggested above, it did fit in RAM,
    and it compiled to 313 WORDS.
    mister_e,
    Yours fit in RAM too, and compiled to 295 WORDS. (unexpected for Select Case)
    You know what that means RIGHT?
    Yup, this ain't over yet!
    172 WORDS
    @ DEVICE WDT_OFF
    DEFINE NO_CLRWDT 1 ' Don't kick the Dog
    lowinput       VAR GPIO.0
    overload       VAR GPIO.2
    green          VAR GPIO.4
    red            VAR GPIO.5
    FlashCount     var byte
    FlashPattern   var byte
    TRISIO = %000111
    Start:
        If (lowinput=0) then
            IF (overload=0) then             ; lowinput, overload, overtemprature
                if (overtemprature=0) then                      ; 000
                    outputpin = 0
                    FlashCount = 1
                    FlashPattern = %0001  ; ModeOK
                    GOSUB FlashLEDs
                else                                            ; 001
                    FlashCount = 5
                    FlashPattern = %0011  ; overtempraturemode
                    gosub FlashLEDs
                    outputpin = 1
            else                                                ; 010
                    FlashCount = 2
                    FlashPattern = %1001  ; overloadmode
                    gosub FlashLEDs
                    outputpin =1
                    FlashCount = 7
                    gosub FlashLEDs
                    outputpin =0
                else                                            ; 011
                    ; --- Action undefined ---
            if (overload=0) then
                if (overtemprature=0) then                      ; 100
                    FlashCount = 5
                    FlashPattern = %1001  ; lowinputmode
                    gosub FlashLEDs
                    outputpin =1
                else                                            ; 101
            else                                                ; 110
                    FlashCount = 5
                    gosub FlashLEDs
                    outputpin =1
                else                                            ; 111
    GOTO Start
    FlashLEDs:
        REPEAT
             green = FlashPattern.0
             red   = FlashPattern.1
             Pause 500
             green = FlashPattern.2
             red   = FlashPattern.3
             Pause 500
             FlashCount = FlashCount - 1
        UNTIL (FlashCount = 0)
    However, omid_juve,
    There are 3 states that are not accounted for
    lowinput=0 overload=1 overtemprature=1
    lowinput=1 overload=0 overtemprature=0
    lowinput=1 overload=1 overtemprature=1
    It may be intentional. Maybe they aren't needed. But normally, unchecked states will cause havoc in your program.
    If we knew what was supposed to happen in those states, I think mister_e ..., uh I mean, I could probably reduce it further.
    Dec 2007
    it a program for 24v to 12v converter that has 3 input 1.over temperature 2.low input 3.overload and we have 3 output that 2 of them is just indicator and one (outputpin)
    is the output for controlling the output voltage according to the situation of inputs.
    and just the modes that you saw in the program can occur .
    thanks for all of your help. my problem is solved .
  1. Loop with two motor and 2 sensors
    Last Post: - 9th December 2008, 00:40
  2. Optimizing DIV
    Last Post: - 22nd September 2008, 05:58
  3. pbp245 compliation error
    By Woodzy in forum mel PIC BASIC Pro
    Last Post: - 25th July 2006, 06:59
  4. 16F88 Compile error
    By Toley00 in forum mel PIC BASIC Pro
    Last Post: - 2nd November 2005, 01:22
  5. Compiler/Assembler Error
    By LT_Pic in forum General
    Last Post: - 21st July 2005, 10:47
