Rs232 and pic
Results 1 to 7 of 7
Thread: Rs232 and pic
    irmus's Avatar
    irmus Guest
    Default Rs232 and pic
    Hello! I try this
    serout portb.2, n2400, [$A0] but its bad .Pic nothing send. Help!!!
    hi irmus,
    try this
    serout PORTB.2,4,[$A0]
    if this ones work, that mean you not declare :
    INCLUDE "modedefs.bas" at the begining of your program
    It appear that in some case that you must write PORTB.x in uppercase too.
    Try also this :
    DEFINE CHAR_PACING 1000
    if this is not working tell me which PIC you use and how it is connected to RS-232 (with in serie resistor, thru an Max232...)
    let us know !!!
    regards
    irmus's Avatar
    irmus Guest
    I am using modedefs.bas . 4 - here it mode baudrate? I use max232 and pic16f84
    when you don't include modedefs.bas SEROUT serpin,4,... is the same as SEROUT serpin,N2400...
    what is your taget device to receive $a0 ???
    $a0= 160 (decimal) = BLANK character in ASCII table
    maybe this is why.
    try PORTB.2,n2400,["hello ",#10,10,13]
    it suppose to display hello 10
    let me know
    One other thing,
    it also seems that SEROUT don't understand $ before data. Only #.
    in your case if you really want to send $a0 use a variable
    ToSend var byte
    ToSend=$a0
    SEROUT PORTB.2,4,[ToSend]
    or
    SEROUT PORTB.2,4,[#ToSend] ; output will be 160
    irmus's Avatar
    irmus Guest
    I use comlite software and i can to see what i send to comport and what data receive from computer.
    Thanks, i try this SEROUT PORTB.2,4,[#ToSend] ; output will be 160
    you're welcome.
  1. SMS via pic
    By kenandere in forum GSM
    Last Post: - 10th March 2010, 10:00
  2. PIC18F4680 to PC via MAX232 (RS232 serial) no output
    By opticsteam1 in forum mel PIC BASIC Pro
    Last Post: - 14th April 2008, 20:39
  3. PC to PIC via RS232
    By Martin.... in forum mel PIC BASIC
    Last Post: - 15th September 2006, 10:44
  4. Waking a sleeping PIC
    By anj in forum mel PIC BASIC Pro
    Last Post: - 19th May 2005, 01:51
  5. PIC to RS232 interface
    By thon in forum mel PIC BASIC Pro
    Last Post: - 12th February 2004, 02:01
