16F877A timer to capture in microseconds
Results 1 to 15 of 15
    Dec 2007
    Malaysia
    Anyone can help me on this?
    Dec 2007
    Malaysia
    Is there anyway to add assembly language to the codes in PicBasic Pro? Can anyone guide me to do polling using timer 1 in 1ms interval?
    Yes it's possible to mix assembler. you just need to use ASM/ENDASM
    	' your asm code goes here
    Unless you define your variable as SYSTEM var, your PBP variable must have an underscore before them
    	YourVar VAR BYTE
    	CLRF _YourVar
    And PBP don't appreciate BANKSEL. you must use CHK?RP instead
    Dec 2007
    Malaysia
    thanks mister_e, this will help me in experimenting the 1ms interval polling. Is there anyone can help me on how to get 1ms interval by polling method for timer1?
    Dec 2007
    Malaysia
    I modified the Olympic Timer program, by replacing the:
    TMR1RunOn.HighByte= $FC
    TMR1RunOn.LowByte=$18
    and deleted the TMR1RunOn=TMR1Preset+TMR1RunOn, to directly load the TIMER1 preset value into the timer1 register.
    This make the timer by the program runs faster than used to. Until I change the value to $FF,$FE, the timer can have the timing interval very close to 1ms, but still slightly delayed, as I compare the timing (seconds) with a watch. The watch is about 2x faster than the timing by the timer.
    Attached is the code I wrote by referring to the Olympic Timer by Melanie. Is there any problem with the code? Any solution for that? Thanks in advance.
    Dec 2007
    Malaysia
    I rewrite a new program to activate Timer1 as free-running timer. I take the TMR1L and TMR1H value directly, and obtain a new result by:
    Result = TMR1H*256+TMR1L
    May I know, is the RESULT I get is in microsecond? As far as I understand, 4Mhz clock will result in 1us per cycle. Thus, is the value obtained in RESULT is in microsecond? Please correct me if I am wrong, I would like to have the result 1 milliseconds. Below is my code, hope some one can correct my mistake.
    ResetTimer:
    GoSub SetRe
    StartTimer:
    LCDOUT $Fe, 1
    LCDOUT $FE, $80, "Calculating..."
    T1CON.0=1
    Start the timer before doing anything with the LCD. The LCD commands take time. It'll skew the result quite a bit.
    GetValue:
    Timer1H=TMR1H
    Timer1L=TMR1L
    When stopping the timer, you'll also have to account for the extra cycles taken during the GOSUBs and other code to get there...if you want a really accurate result.
    And T1 is going to overflow every 65.536us, slightly more than 15 times per second.
    If you press the button at 70,000us, you'll get a result of 4,464, not the result you want.
    How you plan on accounting for the rollover?
    Dec 2007
    Malaysia
    Ok, I will change to Start the timer before doing anything on the LCD. I see, from the explanation, may I know the timer rolloever every 65536 microsecond or 65.536 microsecond? Let's say is it as what Mr.Skimask says, now I understand that the timer will rollover every 65.536 microseconds. May I know how to account the rollover in order to get the incrementing time, instead of keep on doing from 0 to 65.536 microseconds? Is it possible to do something like,
    if Result > 65536 then
    A=A+1
    if A > 65536 then
    B=B+1
    and so on..... I assume that timer1 from 0 to 65536 then rollover to 0 again, and so on. So, when timer1 reach 65536, then A increment by 1, and timer rollover back to start from 0 again. Then, when the 2nd time timer1 reach 65536, A will increment again, and so on. Is this possible? Let A keep on incrementing until I can trace the reading of the timer back in milliseconds? Or is there any better solution? Thanks in advance.
    Sep 2006
    Question Tmr1f?
    I think you could use the Timer 1 interrupt for that.
    But as Miss Melanie says:
    Use the CCP.
    Been on vacation (looooooooooooong vacation ), now I'm back (not that I'm very useful to the forum, I just ask a lot).
  1. mS Timer
    By whmeade10 in forum mel PIC BASIC Pro
    Last Post: - 8th September 2020, 12:12
  2. Using hardware capture
    Last Post: - 25th March 2012, 05:52
  3. High Resolution Timer & Speed Calculator
    By WOZZY-2010 in forum Code Examples
    Last Post: - 7th February 2010, 16:45
  4. Measuring change of frequency with PIC
    By Aussie in forum mel PIC BASIC Pro
    Last Post: - 19th July 2007, 01:47
  5. Reaction timer using 16f877a and pbp
    By sphinxifm in forum mel PIC BASIC Pro
    Last Post: - 14th July 2007, 14:28
