4mhz to 8 mhz
Results 1 to 7 of 7
Thread: 4mhz to 8 mhz
    Quote Originally Posted by Forkosh View Post
    What about PULSIN and PULSOUT
    would their resolution be doubled?
    EDIT: Disregard...wrong post...
    Oct 2007
    Only in versions 7.61 and up. The manual has a good list.
    I have PICBASIC pro version 2.47 . version 7?
    The manual talks all about how PAUSE, PAUSEUS, PULSIN, PULSOUT, SERIN/SEROUT (software based UART type commands), and various other commands are affected by changes in actual oscillator speed and the DEFINE'd oscillator speed. (i.e. faster oscillator, faster this, slower oscillator, slower that).
    PBP compensates for different DEFINE'd speeds (i.e. SEROUT using 2400 baud will be 2400 baud if you DEFINE OSC 4 or DEFINE OSC 40), but can't do anything about what you put into the OSC1/OSC2 pins or what, if anything, you end up selecting for the actual oscillator frequency, either internal or external types.
    Oct 2007
    Smile thx
    Thanks skimask!
  1. TSA5512/5511 code for PIC16F877/84
    By Marin in forum mel PIC BASIC Pro
    Last Post: - 24th August 2013, 06:16
  2. Setting up a 12F683 to run at 20 Mhz
    By johnnylynx in forum mel PIC BASIC Pro
    Last Post: - 3rd March 2009, 02:46
  3. saving RCREG to word
    Last Post: - 15th September 2008, 13:51
  4. Replies: 9
    Last Post: - 31st July 2008, 08:56
  5. SEROUT on 16F876A @ 3.2768 MHz 4MHz Defined
    By brodin in forum mel PIC BASIC Pro
    Last Post: - 16th November 2003, 01:25
