Warning[202]
Results 1 to 10 of 10
Thread: Warning[202]
    Oct 2007
    Vancouver, BC, Canada
    Thanks Darrel.
    I searched through my program, there is a "Hserout" command, I commented it out and there is no further warning.
    I did copy
    DEFINE HSER_SPBRG 46  ' 256000 Baud @ 48MHz, -0.27%
    SPBRGH = 0
    BAUDCTL.3 = 1         ' Enable 16 bit baudrate generator
    when compiled, i got warning message "error[113] \pbp\pbpic18.lib 580 : symbol not previously define(baudctl)
    But anyway I don't need the those DEFINE lines above so I just commented out, and there is no warning. The program when loaded to the pic work fine.
    ________________
    KV
    Oct 2007
    I use USB on board of the pic for transmitting/receiving data.
    ________________
    KV
    There are 2 possible places for the BRG16 bit.
    BAUDCON.3
    - or -
    BAUDCTL.3
    It depends on the chip. And for a 4550 it's BAUDCON.3
    mister_e's calculator has a drop-down box for that.
    But you have to know which one to use.
    But like you said, it's fixed.
    Oct 2007
    indeed, substitue BAUDCTL.3 = 1 with BAUDCON.3 = 1, when compile produced no error.
    ________________
    KV
    Life it isn't easy then
  1. Warning[202]
    By Del Tapparo in forum mel PIC BASIC Pro
    Last Post: - 24th October 2008, 18:41
