PGM for ICSP
Results 1 to 5 of 5
Thread: PGM for ICSP
    Apr 2006
    Alberta Canada
    Default PGM for ICSP
    I'm designing a board around a PIC18F6680, and the datasheets mention that programming can be done with only 2 pins. (PGC and PGD, although MCLR and GND are needed too). In a bunch of posts on here, people say that PGM needs to be grounded with a Resistor.
    does it really need to be grounded, or can i use it as an I/O?
    Yes it can be used as a regular I/O no problem, but this I/O have to be loaded while programming your PIC, unless you may have some programming errors. Sit 1 LED, LCD or whatever else solve problem in most cases. Case not, just add a 10-22K load to gnd.
    Life will be good enough.
    Apr 2006
    Alberta Canada
    so i do need a load on it for programming?? can i have a resistor to ground and then still use it to control a RC servo? so i would be using a pulsout command on that pin. so something like this would work:
    servo
    --------------PGM
    GND
    Yes indeed !
    Apr 2006
    Alberta Canada
    thanks, i will give that a try
  1. F886 & pgm
    By MOUNTAIN747 in forum General
    Last Post: - 9th February 2010, 23:19
  2. HSERIN each character cost 3 pgm words
    By boban in forum mel PIC BASIC Pro
    Last Post: - 7th April 2008, 17:49
