MCLR causing trouble . .
Results 1 to 11 of 11
    Jun 2006
    Bangalore, India
    Question MCLR causing trouble . .
    MCLR pin of 16F84A too sensitive.
    I've explained the problem on the post linked below . . .
    http://picbasic.co.uk/forum/showpost...1&postcount=32
    Now i think its the MCLR pin of the IC that is causing trouble.
    I've given this pin to a 10k resistor and then to Vcc.
    Now even if touch the Vcc grid, the IC resets or 'locks up'.
    How can i resolve this ? ? ?
    shahidali55, What type of filtering do you have on the VCC and VDD lines to the processor? Also is brown out detect enabled?
    Jun 2006
    Bangalore, India
    Post
    Hello Dave
    F84 does not have BOD . . .
    I have used a 100uF cap at the input of 7805 and a 1uF at output.
    The schematic is like the one below
    <center><img src="http://josepino.com/pic_projects/led_clock/JP6282.gif" alt=" Led Clock Schematic "></center>
    The processor resets randomly or just locks up . . .
    I'm using a electronic 12v adapter to power it (SMPS type).
    Because you don't have Resistors to the Common Anodes, if you switch-ON any LED segment for more than a few mS, the current draw will be sufficient to deplete the 1uF Capacitor and your supply will be marginal for operating the PIC.
    I suggest three changes...
    1. Increase the 1uF to 10uF
    2. Put 180R Resistor in each Common Anode
    3. Put a 100nF Capacitor between Vss and Vdd as close to the PIC as possible.
    Bombay, India
    The schematic has some serious flaws as I can see
    1) As it stands, the switches can seriously damage the A & B segment outputs as the supply is directly connected to the port. If the segment is logic 0, it directly shorts the supply to the port pin which may blow the pin or simply short the supply (your reset issue lies here).
    Way out?
    1) The cathodes need series resistors of around 100 Ohms.
    2) A 100n capacitor between VDD and VSS directly across the PIC
    3) Lots of b/cheer ?
    Jun 2006
    Bangalore, India
    Ok, now i have a 100uF capacitor at output of 7805, .1uF directly on to PCB between Vcc and GND. I have already put 120ohm resistors in series with common anodes, the anodes and cathodes are being driven with transistor buffers.
    The PIC resets if i just touch any part of the Vcc grid with a screwdriver in my hand.
    (Also kept it running and it reset after around 3 hours)
    I tried using a 16f628A, same problem even if i disable MCLR at programming...
    Bombay, India
    I have modified the circuit as it should be. It is remarkable that you can reset your cpu by touching VCC. Please mod the circuit as I've shown and let us know how it goes. The resistors shown are all 100 Ohms.
    Are you using a breadboard??? any chance that there's faulty/loose contact on?
    Any chance you have some splitted +/- tracks. mmm maybe a picture would help to explain better
    <table><tr><td></td><td>What i mean is that sometime the supply line on some breadboard brands
    have a break in the middle of their +/- line.
    On the picture, you observe that red and blue line are not continuous,
    This said, don't use it as a reference...
    What i suggest is just do a continuity test on each breadboard + and - tracks between
    each edge (say point 1 and 57).
    might be one cause here...</td></tr></table>
    PCB and DIP socket? any chance the Vss pin is broken underneath the socket... yeah it happen...
    Are you living close to Area 51, Hangar 18?
    Jun 2006
    Bangalore, India
    Thanks for the info . . .
    I've now got 120 ohm resistors in series with the segment pins.
    The buttons are given to a 1K then to GND, internal pullup enebled.
    I'm using pref board. Checked for loose contacts. Did find one but that didn't solve the strange reset problem.
    The IC is resetting when i just make a light touch on the MCLR pin.
    The MCLR pin is given to Vcc through a 10k resistor.
    I've got another clock using the very same circuit and it doesn't reset that easy.
    Could this be due to ESD ? ? ?
    The clock also has a battery backup.
    <img src="http://www.delabs-circuits.com/png_circuits/embedded/battery-backup.png">
    Pin 3 is used to monitor the mains input. (it is given to the output from the 5v reg ,and not the output of battery backup ,through a voltage divider network).
    Could the battery backup be causing a problem ?
    Bombay, India
    Is your power supply based on a transformer or is it one of those low cost capacitive coupled power supplies? I am suspecting that it is the latter one. Then your talk of ESD makes sense. The best option for you to get any valid answer is to post your entire schematic including the power supply. Without that, all answers will be conjecture.
    JF
    Jun 2006
    Bangalore, India
    Smile
    I'm using a SMPS power supply. (from a PC).
    Connecting GND to the case of the XTAL solved my problem.
    I've never had such a problem before and have no idea why giving GND to case of XTAL solved it . . .
    Thank you everyone for helping me out . . .
  1. How to MCLR by code for 16F877
    By fbestepe in forum mel PIC BASIC Pro
    Last Post: - 26th November 2014, 00:51
  2. More trouble - Just can't figure it out.
    By kevj in forum mel PIC BASIC Pro
    Last Post: - 29th August 2007, 11:45
  3. 16F688 Internal clock and MCLR
    By manxman in forum mel PIC BASIC Pro
    Last Post: - 18th August 2007, 18:38
  4. What does this MCLR instruction mean?
    By bartman in forum General
    Last Post: - 30th November 2004, 00:32
  5. I/O pin and MCLR
    By Dwayne in forum FAQ - Frequently Asked Questions
    Last Post: - 15th July 2004, 10:52
