BUG IN PBP 2.50 & 2.50A pic16F688 ??
Results 1 to 14 of 14
    Thumbs down BUG IN PBP 2.50 & 2.50A pic16F688 ??
    TEST PBP 2.50 & 2.50A:
    'DEVICES------------------------------------------------------------------
    @ DEVICE pic16F688,HS_OSC
    @ DEVICE pic16F688,WDT_OFF ' Watchdog Timer
    @ DEVICE pic16F688,PWRT_ON ' Power-On Timer
    @ DEVICE pic16F688,BOD_ON ' Brown-Out Det
    @ DEVICE pic16F688,CPD_OFF ' Data Memory Code Protect 876
    @ DEVICE pic16F688,PROTECT_OFF' Program Code Protection
    'DEFINES-----------------------------------------------------------------
    DEFINE OSC 20
    DEFINE HSER_RCSTA 90h 'Registro receptor en receptor habilitado
    DEFINE HSER_TSTA 24h 'Rregistro de transmisión en transmisión habilitada
    DEFINE HSER_BAUD 19200
    DEFINE HSER_CLROERR 1
    DEFINE NO_CLRWDT 1
    CMCON0=7
    ADCON0=7
    ANSEL=0
    WPUA=0
    WPU=0
    IOCA=0
    PCON=0
    PIE1=0
    TRISA=%00111111
    TRISC=%00100010
    INICIO:
    PORTC.0=1:PAUSE 1000:PORTC0=0 ' LED ON / OFF OK
    OWOUT PORTA.1,1,[$33] ' <----------- PIC STOP , NO GOTO INICIO
    GOTO INICIO
    TEST PBP 2.47
    DEFINE OSC 20
    DEFINE NO_CLRWDT 1
    'ALL DIGITAL MODE
    CMCON0=7
    ADCON0=7
    ANSEL=0
    WPUA=0
    WPU=0
    IOCA=0
    PCON=0
    PIE1=0
    TRISA=%00111111
    TRISC=%00100010
    INICIO:
    OWOUT PORTA.1,1,[$33] ' <----------- PIC NO STOP OK
    GOTO INICIO 'OK GOTO INICIO
    Talking Where's the bug ???
    Hi, Francisco ...
    The Bug is yours !!!
    1st listing
    BAD : PORTC.0=1:PAUSE 1000:PORTC0=0 ' LED ON / OFF OK
    2nd listing
    MCS highlights it at first launch !!! MPLAB too ...
    You offer a beer to everyone here ... LOL !
    Smile BUG IN PBP 2.50 & 2.50A pic16F688 ??
    Well, we like this:
    DEFINE OSC 20
    DEFINE NO_CLRWDT 1
    CMCON0=7
    ADCON0=7
    ANSEL=0
    WPUA=0
    WPU=0
    IOCA=0
    PCON=0
    PIE1=0
    TRISA=%00111111
    TRISC=%00100010
    INICIO:
    PORTC.0=1:PAUSE 1000:PORTC.0=0 ' LED ON / OFF OK
    GOTO INICIO
    TEST PBP 2.47
    DEFINE OSC 20
    DEFINE NO_CLRWDT 1
    'ALL DIGITAL MODE
    CMCON0=7
    ADCON0=7
    ANSEL=0
    WPUA=0
    WPU=0
    IOCA=0
    PCON=0
    PIE1=0
    TRISA=%00111111
    TRISC=%00100010
    INICIO:
    When compiled with pbp 5.xx or higher on the lines OWINOUT the micro stands and not continue the process, the same thing happens if you use SEROUT/SEROUT2. If you compile with pbp 2.47 then it works well.
    Yep. There is a problem in the OWOUT library routine that causes a continuous loop if the
    defined OSC > 8.
    Open your pbppic14.lib. Scroll down to the OWOUT library routine.
    Change this;
        iorwf   INDF, F     ; Set to input then wait ~10us for recovery
        decfsz  R1 + 1, F   ; Do next bit, if any
      if (OSC > 8)
        movlw    9          ; Delay 9us
        call     PAUSEUS
        goto     owoutloop
    To this;
       if (OSC > 8)
        movlw    9           ; Delay 9us
        call     PAUSEUS
        goto    owoutloop
    decfsz R1 + 1, F needs to be after if (OSC > 8) and just before goto owoutloop or you're stuck
    in a nasty continuous loop whenver OSC > 8.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    I don't have this specific PIC here, but yes it seems that once you add the OWOUT line, things goes bad... at least on MPSIM.
    EVEN THAT ONE..
    INICIO:
            PORTC.0=1
            PAUSE 1000
            GOTO INICIO
    Do nothing. It seems to work on a 16F877 so far... worth a report to Melabs.
    EDIT: OK OK... Bruce beat me
    EDIT2: Solution work as expected.
    Wink
    Rhhaaaaa !!!
    Bruce beats everybody ... but how did he know ??? MPsim ???
    I just tested an old DS 1820 4 Mhz program ... that still goes pretty well ...
    Ho... by the way ...
    Bruce, congratulations for your commercial service .... works pretty fine to Europe.
    Hi Alain,
    I just got lucky and looked at the OWOUT library first. MPSIM would for sure have been my
    next choice however.
    Thank you. I wish it worked that well to everywhere outside the U.S....;o}
    -Bruce
    tech at rentron.com
    Thumbs up Thanks and greetings
    Hello everybody, thanks for your good Bruce aportacion, I was crazy with this problem. And tell the technicians of Mlasb: A little more care!
    Thanks and greetings.
    Hi Francisco,
    I have already informed MeLabs of the error in the OWOUT routine. I'm sure they will release
    a patch shortly to fix the minor error.
    This is one major reason it's so nice to have an open library. You're not dead in the water
    until a re-compiled patch comes out. Just fix it, and move on. Really a nice feature with PBP.
    -Bruce
    tech at rentron.com
    Cool I have a question ?
    I have a question also affects serout/2 because also the same case.
    Greetings
    What problem are you having with SEROUT2?
    -Bruce
    tech at rentron.com
    Unhappy Serout problem
    With this microprocessor the same problem with owinout was detained when the process is executed the command serout2.
    Feb 2003
    Sydney, Australia
    Default Newer version with this bug fixed ?
    Did this ever get fixed ? I can see 2.50a on the Melabs site, but nothing newer. I assume this bug is still valid.
    bill
    Hi Francisco,
    Quote Originally Posted by bcd View Post
    bill
    I'm not going to mess with my installation...it works too smoothly.
    I guess the only way to figure out if 'A' fixed the problem is to install 2.50, check the macro, install the patch, and check the macro again.
  1. PBP 2.50 and Longs
    By mikendee in forum GPS
    Last Post: - 21st May 2008, 22:16
  2. PBP bug ???
    By boban in forum mel PIC BASIC Pro
    Last Post: - 19th March 2008, 17:30
  3. PBP 2.50 UPGRADE problems!!!!
    Last Post: - 7th March 2008, 16:42
  4. Strange problem with PBP 2.50
    Last Post: - 16th October 2007, 21:45
  5. MCS+ with PBP 2.50
    Last Post: - 21st September 2007, 06:52
