Again I need a solution that is physically isolated from the source path. This is why I was looking at the current transformers.
Yes, they are isolated.
I have used both current transformers and Allegro devices, and I only use the Allegro parts now because of their size, accuracy and ease of use. Even though I mostly use the larger devices, I have used their smaller parts (SOIC-8 package) to measure currents below 100mA.
Charles Linquist
from what I can see the circuit to be sensed needs to be cut and routed through Ip- and Ip+on the allegro devices.
I need something that does not disturb the circuit to be sensed.
That is true. Looks like you want a clamp-on current probe. I can't help you there. Sorry!
Charles Linquist
