AC current metering
Results 1 to 10 of 10
    Sep 2006
    Default High current indeed...
    Quote Originally Posted by Charles Linquis View Post
    The model depends on the maximum current. We use the ACS752, but then we are measuring some really high currents.
    50 to 100 amps (that's pretty high).
    Jan 2006
    Again I need a solution that is physically isolated from the source path. This is why I was looking at the current transformers.
    Dec 2005
    Quote Originally Posted by docwisdom View Post
    The Allegro chips provide electrical isolation of several kV. I'm not sure what you mean by physically isolated.
    Sep 2005
    Campbell, CA
    Yes, they are isolated.
    I have used both current transformers and Allegro devices, and I only use the Allegro parts now because of their size, accuracy and ease of use. Even though I mostly use the larger devices, I have used their smaller parts (SOIC-8 package) to measure currents below 100mA.
    Charles Linquist
    Jan 2006
    from what I can see the circuit to be sensed needs to be cut and routed through Ip- and Ip+on the allegro devices.
    I need something that does not disturb the circuit to be sensed.
    Sep 2005
    Campbell, CA
    That is true. Looks like you want a clamp-on current probe. I can't help you there. Sorry!
    Charles Linquist
  1. Replies: 8
    Last Post: - 5th May 2009, 20:10
  2. Circuit Diagram for interfacing AC to PIC IC?
    By wellyboot in forum Schematics
    Last Post: - 8th March 2008, 19:40
  3. 16F628A current high during sleep
    Last Post: - 9th October 2006, 10:21
  4. Special Offer AC -AC adapter
    By lester in forum Adverts
    Last Post: - 9th September 2005, 07:52
  5. Detecting AC current
    By rhino in forum Off Topic
    Last Post: - 8th July 2005, 21:31
