How to drive the Vinculum VDIP1 in UART mode
Results 1 to 40 of 42
    May 2010
    Default VDIP Doesnt connect to flash drive
    Hi Guys, I have a issue which is driving me nuts...
    When I connect either one of my flash drives to the VDIP module, nothing happens...
    When I apply VCC 5V to the device the leds blinks alternating then stops this happens when i start the module in spi or FIFO mode with or witout my flash drives. However when i start the module in UART the led's blinks continuously even when i connect my flash drives.
    1) Both my flash drives are not working with the VDIP, because they work perfectly on the pc
    2) my VDIP is blown, but also unlikely because i can re flash is using my rs323rl board.
    Does anyone had this led issue or what to do when vdip does not recognize your flash drives.
    Help will be greatly appreciated
    Feb 2010
    Wink :)
    Quote Originally Posted by Jacques View Post
    hi Jacques,
    i think the problem is that the VDIP is unable to send bytes (Confirming that it is online) because of its UART Connection. Can you try to connect the CTS of the VDIP to the ground? may be this will solve it.
    Best Regards!
    May 2010
    Default :)
    Page 101, youre a rock star thx man,
    Now its the tricky task of getting it to work in fifo mode.
  1. VDIP1 (Vinculum - FTDI) problems
    Last Post: - 20th August 2013, 14:51
  2. MPASM Path & File Name Length Limtation
    By Brian J Walsh in forum mel PIC BASIC Pro
    Last Post: - 14th June 2008, 16:48
  3. Oscillator stops when touching with a wire
    By Wilbert Ingels in forum mel PIC BASIC Pro
    Last Post: - 25th April 2008, 09:51
  4. USB-FTDI[UM232R] with PIC16f877a
    By bjox in forum USB
    Last Post: - 23rd February 2008, 23:40
  5. Replies: 14
    Last Post: - 26th September 2007, 06:41
