How to drive the Vinculum VDIP1 in UART mode
Results 1 to 40 of 42
    Default Re: How to drive the Vinculum VDIP1 in UART mode
    It has been a couple of years since I played with this so I have not kept up with the new stuff.
    I think I was using the Vinculum Firmware Customiser (V1.1b) found here
    http://www.ftdichip.com/Firmware/VNC1Ltools.htm
    When the data logger is plugged into a PC is the software needed to read it or can it be accessed as a drive? If it can not be accessed as a drive I do not think the VDIP will help.
    pthakkar's Avatar
    pthakkar Guest
    Hi
    I am using VDIP1 module in UART mode. I have been able to interface the module and everything works fine as long as I use a pen drive of capacity 2 GB or less. I read in the datasheet that the pen drive must have 512 bytes per sector and in 4GB pen drive this option is not available.
    The issue is that I cannot find pen drive with capacity less than 2 Gb in the market. So is there any way I can use 4GB pendrive with VDIP1?
    They're not cheap but are available here:
    http://www.amazon.com/Kingston-Trave...3518109&sr=1-4
    Hi pthakkar,
    I am using VDIP1 module in UART mode. I have been trying to interface the module with my 8051 controller. But so far I have not been able to send the data from microcontroller to the pen drive visa VDIP1 module. Can I get some input from you?
  1. VDIP1 (Vinculum - FTDI) problems
    Last Post: - 20th August 2013, 14:51
  2. MPASM Path & File Name Length Limtation
    By Brian J Walsh in forum mel PIC BASIC Pro
    Last Post: - 14th June 2008, 16:48
  3. Oscillator stops when touching with a wire
    By Wilbert Ingels in forum mel PIC BASIC Pro
    Last Post: - 25th April 2008, 09:51
  4. USB-FTDI[UM232R] with PIC16f877a
    By bjox in forum USB
    Last Post: - 23rd February 2008, 23:40
  5. Replies: 14
    Last Post: - 26th September 2007, 06:41
