Homicidal 877 user needs help
Results 1 to 34 of 34
    Dec 2007
    Northants England
    Thought the osc had to be set to intrc to use the internal oscillator, now realise it should be set to XT. Have now written simple program to switch on all port b pins, pause and swithch them off again in an endless loop. The program containsthe line cmcon = 7 can't remember why but I recall having to do this about a year ago when I wrotethe original star program. The osc isset to XT it compiles and produces the attached hex file but fails to flash the ports
    Mar 2006
    Pennsylvania, USA.
    David,
    If you're using a 20 MHz crystal the oscillator has to be set for HS (High Speed) XT is for a 4 Mhz crystal. I've never used the internal oscillator as all of my projects seem to need serial ports or something that requires better timing.
    Dave,
    Thanks, I never thought of that!
    Jerry.
    If your oscilloscope costs more than your car...
  1. LCD graphic for user manuals
    By wjsmarine in forum Documentation
    Last Post: - 27th August 2009, 12:43
  2. new user with problem using PGP Pro, Lab-X3 with 16F628A
    By equipoise in forum mel PIC BASIC Pro
    Last Post: - 28th July 2004, 08:42
  3. '877 and Visual Basic 6
    By Tomas in forum mel PIC BASIC Pro
    Last Post: - 4th March 2004, 03:31
  4. User Configuration Interface in PBP
    By Radiance in forum mel PIC BASIC Pro
    Last Post: - 7th February 2004, 09:00
