Homicidal 877 user needs help
Results 1 to 34 of 34
    Mar 2006
    Pennsylvania, USA.
    Question
    Dave,
    How do you know where in the hex file the oscillator setting is? I was proud of myself because I could count to ten in hexadecimal, but now I'm just amazed that you could decipher that. You gave me a good idea though, David could go under View in the EPIC programmer window, and post exactly what the configuration is set to, and then look under Options as Bruce suggests in the other post regarding the re-read file setting.
    Jerry.
    If your oscilloscope costs more than your car...
    If I did it right.
    Opened MPLAB, set the Pic Being used, import the hex and see what MPLAB has for the configuration.
    This may not be the best way but it seems to work.
  1. LCD graphic for user manuals
    By wjsmarine in forum Documentation
    Last Post: - 27th August 2009, 12:43
  2. new user with problem using PGP Pro, Lab-X3 with 16F628A
    By equipoise in forum mel PIC BASIC Pro
    Last Post: - 28th July 2004, 08:42
  3. '877 and Visual Basic 6
    By Tomas in forum mel PIC BASIC Pro
    Last Post: - 4th March 2004, 03:31
  4. User Configuration Interface in PBP
    By Radiance in forum mel PIC BASIC Pro
    Last Post: - 7th February 2004, 09:00
