and a .HEX file of your PIC program, so we can confirm your configuration fuses are set correctly. If you set them in your programmer software, you should be able to save the .HEX file, so the next time you open it, those should be set as you did.
also check if your software is set to program the configuration fuses.. yeah it happened.
