Homicidal 877 user needs help
Results 1 to 34 of 34
    Dec 2007
    Northants England
    Hi James,
    I have always suspected the config settings but must have tried most of the permutations by now ! The settings as at the last failed test were:
    oscillator XT (whilst I have the resonator in circuit)
    power up timer is enabled but nothing else under the config menu
    i.e.Watchdog timer,Brown out reset lvp Flash program write are all disabled
    Can't see any reference to mclr but I do have 1K to +5 voltson pin 1
    Thanks for the suggestions
    Cheers
    David
    Mentor, Ohio
    Smile
    Hi David,
    Maybe we are getting somewhere afterall. You stated that you put in a 10 pin header to allow ICSP. Did you also add the diode to block the voltage from going to the rest of your circuitry? I use ICSP to program a product I make and I do not have any +5vdc connection between the programmer and the pcb. I only use the mclr, ground, RB6, and RB7 pins. When I did another project several years ago with an 877A I also had problems doing ICSP so I gave up on the idea. I have since worked out the problems by just using the connections I gave above. I have read in several places that the PGM pin should be grounded during the programming process.
    Do you have a simple breadboard that you can setup a very basic 877A with the mclr to +v thru a 1k resistor, put a led/resistor on RB0, add the 4mhz resonator and then test out the blinky program? This could help isolate whether its the PIC or your boards. You should be able to create the blinky program without adding any config settings. Just use the one that's in the MCS program.
    HTH,
    BobK
    Mar 2006
    China
    Default Can you post a picture?
    Could you post a picture of your HW and maybe a simple schematic. There must be a reson for the PIC not to work properly and we all wants to help.
    A simple schematic will help to provide us an understanding of what levels you have where and if we compare these with what we expect them to be we might be able to spot the problem.
    What does RB6 and RB7 do after you have ISCP-programmed the PIC and disconnected the programmer? I have seen of the 877A that if RB6 and RB7 are held at an unfourtunate level/timing the PIC will refuse to start up properly. I suspect this to be related to the VDD rise and then the PIC will try to enter programming mode even when a programmer is not connected.
    I have 2 877A:s connecting with each other using a cable on RB6 and RB7. And if I set the pins from one PIC in a special way the other PIC will refuse to power up.
    Are there any power applied to any pin of the PIC before VDD is applied?
    /me
    and a .HEX file of your PIC program, so we can confirm your configuration fuses are set correctly. If you set them in your programmer software, you should be able to save the .HEX file, so the next time you open it, those should be set as you did.
    also check if your software is set to program the configuration fuses.. yeah it happened.
    The ICSP might be it.
    I use a PICSTART PLUS for ICSP. Just tried a 16F877A.
    All works well when the programmer is powered. If I leave the programmer connected with the programmer power off the PIC will not start.
    HTH
    Dec 2007
    Northants England
    Thanks all, I am assimilating your comments and will respondwith code details etc. asap. However we are shortly seeting off for a pre Christmas long weekend in Brussels and senior management is going to get difficult if I am caught at the keyboard much more. Thanks again will be back on line asap
    David
    Mar 2006
    Pennsylvania, USA.
    David,
    I went through almost the exact same scenario almost two years ago, and after losing a little too much hair I discovered that the problem lay in my epic programmer, the one that uses the printer port. Windows XP was playing havoc with the printer port on occasion. I upgraded to the newer USB programmer from MELABS, and have not had a hardware problems since. I still get the occassional software glitch, but as those are all self inflicted............. Anyway, perhaps someone a little closer to you might offer to program a 16f877 for you, and see if that works. I would be awfully suprised to learn that you have 6 defective chips and three defective development boards, my lab-x boards run continuously, and have never been a problem. The programmer seems to be the only thing that is common to all your problems, as you said you should be able to blink an led without any difficulty.
    Jerry.
    If your oscilloscope costs more than your car...
    Dec 2007
    Northants England
    Few quick words before heading for the channel tunnel. Built a quick breadboard just the four power supply connection, resonator 1Y pullup on pin 1 and and led on RB7. With the software recommended earlier in this thread ... nothing... except, as once before when using the crystal if I touch pin 13 then the led flashes, trouble is its flash rate doesnt seem to have much to do with the program !! Jerry you could be right about the epic, I seem to recall having problems with it in the past I will look into it when I get back from the Brussels trip.
    Cheers everyone
    David M
    Default Hmm
    There's a fix for printer port issues and epic.
    from melabs download section:
    Stop Windows XP from polling printer port
    Windows XP may periodically access printer ports and interrupt the EPIC™ programming process. This can be stopped with a registry entry.
    Download the registry entry file below and merge it into your XP registry.
    Download XP_stop_polling.reg (1K)
    http://www.melabs.com/support/patches.htm
    it programmed and verified ok, there's something wrong with the code or hardware, be it config fuses or tris or icsp left connected.
    As far as programming and verifying ok, lol, I just had a hell of a time with my led project. thought I fried the pic, programmed and verified perfectly. spent 3 hours only to find I goofed and set the trisa and trisb to 255 (all inputs) oops! inputs aren't going to make anything blink. lol don't they default to inputs if tris isn't set?
    my programmer, if left connected puts -7volts on all the pins.. definately not a good idea.
  1. LCD graphic for user manuals
    By wjsmarine in forum Documentation
    Last Post: - 27th August 2009, 12:43
  2. new user with problem using PGP Pro, Lab-X3 with 16F628A
    By equipoise in forum mel PIC BASIC Pro
    Last Post: - 28th July 2004, 08:42
  3. '877 and Visual Basic 6
    By Tomas in forum mel PIC BASIC Pro
    Last Post: - 4th March 2004, 03:31
  4. User Configuration Interface in PBP
    By Radiance in forum mel PIC BASIC Pro
    Last Post: - 7th February 2004, 09:00
