Timer Interrupt to exit a closed loop
Results 1 to 8 of 8
    North Norfolk UK
    Hi Steve
    Sorry I forgot to mention It is in an 18F4520, actually it's on a fairly well modified LABX1 board, Ill migrate to a suitable MCu after I have finished.
    and I had a scout about the forum for info about the VB code to do all sorts of wonderfull things to the post
    define OSC 16
    INCLUDE "DT_INTS-18.bas"       ; Base Interrupt System
    INCLUDE "ReEnterPBP-18.bas"    ; Include if using PBP interrupts
            INT_Handler   CMP_INT,  _StartTag,       PBP,  yes
            INT_Handler   TMR0_INT,  _AllDone,        PBP,  yes
        INT_CREATE
    TRISA =  %00001111
    TRISB =  %11011111
    TRISC =  %00111111
    TRISD =  %00000000
    PORTD = 0
    Z var byte
    T0CON   = %10000011    'set up timer 0 and turn it ON  @16mhz 0011 = 262ms
    CMCON   = %00100011    ' set up comparator inputs
    @ INT_ENABLE  TMR0_INT          ;all done
    T0CON.7 = 0                     ' turn off timer until needed
    start:
    portd.5 = 0
    Get_Raw_Data:'          GET RAW DATA
    '-------------------------------------------------- Z = 0-----------------
    @ INT_ENABLE  CMP_INT            ;wait here until an  interrupt event
    Z = 0                                     'on the comparators
    Waiting:
                if z = 0 then waiting
    @ INT_DISABLE CMP_INT
    '----------------------------------------- Z = 1--------------------
    portd.5 = 1                           'all done marker
    TMR0H = %00111100                     ' preload timer to 15400
    TMR0L = %00100000
    T0CON.7 = 1                    ' turn back on timer 0 , used by all done
    getData:                          ']loop here until timer1 overflows
    if z = 1 then getdata             ']
    '--------------------------------------------Z = 4-----------------
    getout:
    PORTD.5 = 0                      'all done marker
    T0CON.7 = 0                       'turn timer0 off until used again
    finished:
    goto start
    ;;;;;;;;;;;;;;;;;;;;;      interrupt handlers        ;;;;;;;;;;;;;;;;;;;;;;
    StartTag:
    z = 1              ' moves towards middle of routine
    @ INT_RETURN
    AllDone:
    z = 4             ' moves towards end of routine
    @ INT_RETURN
    simple
    Loading the timer: I have read somewhere (datasheet maybe?) that it is good practice to have the timer running before you initially start an interrupt which I do in the setup. I then enable interrupt and turn the timer off so that I can preload and then turn it back on when I am ready to start the stopwatch.
    I have tried it another way which is to setup prescale and leave timer off /then preload and when I am ready to use it I start timer with the enable interrupt on the next line, regrettably the same thing happens.
    I cannot help feeling I am missing something really fundamental. This problem has been around for me for a couple of weeks now, I am ready to stich the module back into the main compilation... feeling pretty dispondent and mentally tired.... i really appeciate your input.
    North Norfolk UK
    Hi Darrel,
    Thanks just got your reply, although I using the comparators to feed the CCp modules. As you say the cmp interrupt is on *any change on either comparator*
    so i am using the cmp as a sort of interrupt on change on both analog pins. It is then inportant to disable the cmp interrupt as soon as possible. I did have one comaparator output (the one i felt most probable to set) linked to portb internal interrupt but it oscillated like crazy, I get little or no bounce using this setup. I had been disabling the cmp_int "inside" it own handler routine but felt that this was bad practice (any thought?)which I why I try to keep the sub routines as simple as posible ie Z=1 or Z=2.
    I have tried introducing delays without using pause (small count loops) to allow the interrupt disable to settle.
    but I guesss that whilst I have been concentrating on timer0 as the culprit I should be back looking at CMP_INT to see if there is any way this could be responsible. But this loopback is happening 206ms after I have disabled CMP.
    I also check that Z variable that I use as a progress gate is not corrupted, that is to say that even though Z = 1 the program is passing through a conditional IF's that should prevent it, confused........ I am totally.
    North Norfolk UK
    well it looks as if I have found a workaround, it seems as if the first line after the
    @ INT_ENABLE CMP_INT is being ignored furthermore placing Z = 0 at any position from start to the @ INT_ENABLE CMP_INT will also cause a problem so I have to place a dummy line after the enable and everything works as it should do....... or so it appears on the surface to.
    Z = 0                             'dummy line ignored
    Z = 0
    Waiting:
    if Z = 0 then Waiting
    I have only one variable in the example. I do not think I can face it but I have a feeling that I may have to check the stability of all my variables before and after an interrupt implementation .
    I have just pulled the whole house down to find a needle ......... but for the want of that needle.... I am cold wet and have nothing to cook on!!!
    think I will go down the road and post a christmas card to myself
    That's the correct way.
    Comparators can give many interrupts right at the point where it switches (hundreds even, if the analog signal is slow). If it's allowed to return from the interrupt without disabling, it'll end up right back in the handler again until it's past the switching point of the comparator. External hysterisis can be added to the comparator to eliminate that, but it's not needed in this case.
    Also, much like the PORTB change interrupt, you should read the CMCON register inside the handler to end the mismatch condition. Typically, the handler would do that anyways to determine which comparator fired.
    And,
    before enabling the comparator the first time. Read CMCON, then Reset the interrupt flag.
    Then be sure to clear it again before re-enabling later. The flag may have been set during the time it was Disabled.
    No need,
    Nothing happens to your other variables during an interrupt, unless you specifically change them in the handler.
    North Norfolk UK
    Hi Darrel
    Thankyou for your help..., again. I was experiencing occasional hysterisis whilst using the internal comparators but by slightly increasing the speed of the analog signal along with placing two bypass caps on each VDD pin of the MCU the internal bounce was brought easily under control.
    By executing strict good housekeeping with respect to the flags and reading the cmcon register as you advised (it is in the Datasheet) together with re-setting all the registers prior to re-enabling I now have all six interrupts functioning perfectly within the same sub-routine and all being disabled upon exit. I am delighted and relieved, i almost feel a poem coming on but I note you recently penned something apt.
    I can fly effortlesly ..... so until I have to learn how to land I am enjoying the moment.
  1. Elapsed Timer Demo
    Last Post: - 29th October 2012, 17:39
  2. Controlsystem for compact sporting (clay shooting)
    By Fredrick in forum mel PIC BASIC Pro
    Last Post: - 30th July 2009, 16:48
  3. Can't ID interrupt source with this IntHandler??
    Last Post: - 3rd June 2009, 02:35
  4. Using input from Switch to control a loop
    Last Post: - 2nd February 2009, 05:02
  5. Serial Relays
    By tazntex in forum General
    Last Post: - 17th May 2007, 17:42
