pic '877 ADC...PLease HELP !!
Results 1 to 5 of 5
    nice snowy winter so far....Eh !
    yeah, for once we have it before march
    is any type of pullup/down resistor required on the adc input, or would that cause inaccurate readings ?
    Not really, but depending what is sending you the voltage... the main concern is more the output impedance your sensor show to the adc. It MUST be lower than the maximum recommended in the datasheet. Adding a simple 0.1uF capacitor is also handy to smooth the results.
    And according to your calculations, would upping the sample time to 20uSec be better and how do control the input impedance to get the right value?
    well you're really not as this off. 1uSec is nothing, and you're using the slowest conversion clock, so i wouldn't worry to much about that now.
    Also, how do I convert my adc "A0" value to volts?
    simple maths. 1024=5V
    (ADCResult*5)/1024
    put 512 as adcresults, and woohoo, you have 2.5 v. but yeah, PBP don't work with floating points... so you need some maths again.. Depending of the accuracy you want, you may use a variant of the above. say
    (ADCResult*500)/1024
    512 return 250? 2.50 volt.
    You need to care about the overflow, */ could be used.
    Bellow is a short example of it
    http://www.rentron.com/AD_LOG.htm
    Question
    Hi, Steve
    There's something hurting me in the listing ...
    Quanta CON 1251 ' For 10-bit A/D +Vref = 5V : 5V/1023*256=1.251=Quanta
    shouldn't it be Quanta = 5v/ [b]1024[/b) * 256 ... ???
    That's what all my datasheets tell ... with 5v ref : "code 1023" is 4.99878 v ...
  1. 12 bit or higher ADC on a PIC that works with PBP?
    By Brandon in forum mel PIC BASIC Pro
    Last Post: - 11th November 2007, 17:19
  2. Flash PIC with 12 bit ADC
    By Steve_88 in forum mel PIC BASIC Pro
    Last Post: - 12th October 2007, 20:35
  3. ADC -how it works?, pic -
    By matias in forum mel PIC BASIC Pro
    Last Post: - 13th March 2007, 21:54
  4. I2C Slave, config Vref - + in pic with ADC
    By sebapostigo in forum PBP Wish List
    Last Post: - 5th March 2007, 03:21
