pic '877 ADC...PLease HELP !!
Results 1 to 5 of 5
    Dec 2007
    Toronto, Ontario
    Default pic '877 ADC...PLease HELP !!
    I am fairly new to this whole pic chip thing, and loving it !
    I'm building a small (hopefully autonomous) robot and slowly I'm getting close to my goal.
    Using a set of Ewave radios and the melabs bootloader, I am able to wirelessly program my pic16f877-04/p, which is pretty cool. All motor control is accomplished using two moded rc servos and an L293D motor driver. Anti-collision will be done using a few Sharp GP2d12 IR range finders. Having the RF modems of course is good for more than just programming. My plan is to be able to tx live onboard telemetry from the robot to my PC or to an RF terminal/user controller and display on a serial LCD.
    Should be easy enough, ya right !!! I'm now on day 3 with no luck.
    So in order to have any telemetry I first must convert my analog reading to digital, which IS my problem.
    I would like to read 0-5v on channels A0,1,2,3 and then serially display on portb.5.
    I'm using a 4x20 serial LCD for now hooked up to the PIC, not using wireless until the ADC starts working. In my program below, I'm just looking at two inputs as an experiment, and they do display some value, but nothing correct. I have really tried to get the ADCON settings right, but to no avail. Also, which is better or easier to use, 8 or 10 bit ?
    ' 10-bit A/D conversion
    ' Define ADCIN parameters
    ' Set number of bits in result
    define loader_used 1
    pause 20
    DEFINE ADC_BITS 10
    ' Set clock source (3=rc)
    DEFINE ADC_CLOCK 3
    ' Set sampling time in microseconds
    DEFINE ADC_SAMPLEUS 10
    X VAR WORD
    A0 VAR WORD ' Create variable to store result
    A1 VAR WORD
    A3 VAR WORD
    ' Set PORTA to all input
    TRISA = %11111111
    ADCON1=4 'SETS PORTA 0,1,3 TO A/D INPUTS
    serout portb.5,2,[12] 'clears LCD
    Pause 500 ' Wait .5 second
    ADCIN 0, A0 ' Read channel 0
    PAUSE 100
    ADCIN 1, A1 ' " " 1
    PAUSE 100
    ' do something with A0-A2 here
    SEROUT portb.5,2,[128,17,22,"BUSS VOLTAGE : ",#a0,145,"vDC"]
    SEROUT portb.5,2,[148,"IR DISTANCE : ",#a1,164," cm"]
    SEROUT portb.5,2,[168,"TRANCEIVER : "]
    SEROUT portb.5,2,[188,"TEMPERATURE : "]
    Pause 200 ' Wait .2 secondS
    GoTo main
    ' Do it forever
    alarm:
    serout portb.5,2,[12,128,"-------ALARM--------"]
    serout portb.5,2,[168,"LOW VOLTAGE..: ",#A0/175,185,"vDC"]
    PAUSE 200
    GOTO MAIN
    any help is much appreciated,
    JK
    Hi and welcome!
    i see 1 small mistake ADCON1 setting. When you use 10 bit resolution, you have to specify to right justify your results, unless, yeah they might be weird.
    ADCON1 = %10000100
    Now depending of your external impedance the Acquisition/sampling time might be too small. Let's see the worst case... 4MHz, 10K impedance, min acquisition time 11uSec... bah... probably not enough to screw things.
    Sounds like an interesting project so far
    Dec 2007
    Toronto, Ontario
    Smile
    hi,
    Thanks alot for your prompt reply mister e ! I will try that code change and see what happens. A few more questions: is any type of pullup/down resistor required on the adc input, or would that cause inaccurate readings ? And according to your calculations, would upping the sample time to 20uSec be better and how do control the input impedance to get the right value? Also, how do I convert my adc "A0" value to volts?
    thanks again,
    BTW, nice snowy winter so far....Eh !
    John
    yeah, for once we have it before march
    Not really, but depending what is sending you the voltage... the main concern is more the output impedance your sensor show to the adc. It MUST be lower than the maximum recommended in the datasheet. Adding a simple 0.1uF capacitor is also handy to smooth the results.
    well you're really not as this off. 1uSec is nothing, and you're using the slowest conversion clock, so i wouldn't worry to much about that now.
    simple maths. 1024=5V
    (ADCResult*5)/1024
    put 512 as adcresults, and woohoo, you have 2.5 v. but yeah, PBP don't work with floating points... so you need some maths again.. Depending of the accuracy you want, you may use a variant of the above. say
    (ADCResult*500)/1024
    512 return 250? 2.50 volt.
    You need to care about the overflow, */ could be used.
    Bellow is a short example of it
    http://www.rentron.com/AD_LOG.htm
    Question
    Hi, Steve
    There's something hurting me in the listing ...
    Quanta CON 1251 ' For 10-bit A/D +Vref = 5V : 5V/1023*256=1.251=Quanta
    shouldn't it be Quanta = 5v/ [b]1024[/b) * 256 ... ???
    That's what all my datasheets tell ... with 5v ref : "code 1023" is 4.99878 v ...
  1. 12 bit or higher ADC on a PIC that works with PBP?
    By Brandon in forum mel PIC BASIC Pro
    Last Post: - 11th November 2007, 18:19
  2. Flash PIC with 12 bit ADC
    By Steve_88 in forum mel PIC BASIC Pro
    Last Post: - 12th October 2007, 21:35
  3. ADC -how it works?, pic -
    By matias in forum mel PIC BASIC Pro
    Last Post: - 13th March 2007, 22:54
  4. I2C Slave, config Vref - + in pic with ADC
    By sebapostigo in forum PBP Wish List
    Last Post: - 5th March 2007, 04:21
