Hi, Ioannis
The problem here is the sensor "1" level lasts only 1µS ....
the only solution I see here is use an asm part to generate the high state and test the pin as soon as end of high state .
If i remember ... it's the trick used to test if a pin is low, high or Hi-Z ... !!!
( thanks for the last picture, Sayzer ...)
