Does my code need tidying up?
Results 1 to 4 of 4
    Dec 2007
    Default thanks
    Thanks bearpawz,
    It's been a steep learning curve for me... The forum has proved to be an invaluable resource. Just last night I managed to finally get my data to store and retrieve nicely from an external eeprom by reading the many eeprom problem threads on here. Turned out my whole issue was I had the control declared as a word, not a byte.
    What you say about commenting the code is a very good point. I will endeavor to do that more.
    Quote Originally Posted by davewanna View Post
    Hi davewanna,
    Do yourself a huge favor and do it to this code right away, while you still have direct knowledge as to what every line does, also add notes as to what did not work, so 6 months from now you will not have to reinvent the wheel.
    JS
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 22:55
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  5. Re-Writing IF-THEN-AND-ENDIF code?
    Last Post: - 18th August 2006, 18:23
