microCode ver MPLAB
Results 1 to 6 of 6
    Default microCode ver MPLAB
    Any comments on witch one is the best
    Depending of the job and what you expect of an IDE.
    MPLAB
    Pro
    1. a kind of sim/debugger (software.. not real-time, not hardware)
    2. a sort of logic analyser
    3. project manager
    4. code folding (expand/collapse)
    5. multiple language toolsuite support
    6. Free
    con:
    1. serial comm terminal
    2. full code explorer(include, variable etc,etc), limited to label only
    3. toolsuite helpfile
    4. no support for most third party device programmer
    5. a bit tedious to use, bloat
    MicroCode
    PRO:
    1. full code explorer
    2. easy to use, light
    3. built-in serial communicator/terminal
    4. easy to use/implement ICD (paid version)
    5. bootloader (paid version)
    6. support for any third party device programmer
    7. context helpfile
    CON:
    • single toolsuite support
    • no code folding
    • no project manager
    Depending your definition of better/worst. Both do the job.
    Hi Andre-
    This is a PBP Forum, right? Then you should be looking to use a PBP enhanced IDE, and IMHO there is no question that Microcode MCS is the answer. For PBP, it is simple, quick, elegant. Also, be aware that MCS can use the MPLAB assembler (for 18F) as well as their own assembler (16F). The Microchip MPLAB IDE is optimised for C programmers, and as Steve says, is full of bloat. You can integrate PBP into MPLAB, but I find the operation clumsy.
    Hope that this helped
    regards
    Angus Anderson
    Jan 2008
    Default MPLAB vs MCSP
    Apparently what I understand is that if you want to use the In-Circuit-Debug (ICD) function from MicroCode Studio Plus you need a PIC which has a built in USART and this hw USART is used by the ICD. So you application running into the PIC under debug cannot use the USART for something else within your own code.
    May be I'm wrong but this is what I understood. If this is true, it could be a serious for some application requiring the use of the USART.
    pf
    Fair enough, I will have a serious look at microcode, one other question will my microchip mplab ICD2 work with microcode?
    Jan 2008
    Default ICD2 and Picbasic
    ICD2 works with MPLAB 8.01 you can download and integrate PICBASIC PRO
    It doesn't work with Microcode Studio Plus because as far as I know it doesn't exits an executable (.EXE) file to drive the ICD2 debugger/programmer. It's fully embedded into the MPLAB development suite.
    This is too bad!
    pf
  1. MpLAB icd 2 Microcode studio plus
    By mitchf14 in forum mel PIC BASIC Pro
    Last Post: - 26th January 2009, 23:40
  2. Upgraded to MPLAB IDE 8.14 and now I'm stuck
    By BlueHairBob in forum General
    Last Post: - 20th August 2008, 02:15
  3. MicroCode Studio VS Mplab
    By tonyfelloni in forum mel PIC BASIC Pro
    Last Post: - 20th May 2008, 20:49
  4. Microcode Studio MPLAB support
    By jbpaul in forum General
    Last Post: - 27th November 2006, 07:55
  5. MPLAB ICD ver 1 & 16F628A
    Last Post: - 26th February 2005, 01:44
