ISD1700 series Winbond chipcorder
Results 1 to 13 of 13
    Mar 2009
    Hi Joel,
    This forum thread might help, although they do all their SPI commands via bit banging. Good luck
    http://www.picbasic.co.uk/forum/show...6106#post86106
    Alan
    Mar 2009
    Hi Joel,
    I think I might have an answer for you if you're still working through your issue. I have my ISD1700 and PIC recording and playing. I also had the same issue where it appears to stop working. One of the things I realized is that if I send a record command or play command that blinks the LED, if I send a read status without the fourth bit enabled for the LED, the LED will not come on or blink for the record and play respectively. So I realized that the chip was still recording although the LED wasn't playing. Any new command you send should set the fourth bit to keep the LED working.
    How's the programming coming for you?
    Alan
  1. Winbond ISD1700 Voice Recorder
    By RFEFX in forum mel PIC BASIC Pro
    Last Post: - 22nd April 2014, 10:00
  2. ISD1700 series
    Last Post: - 30th October 2008, 23:57
  3. Series resistor when using weak pull-up
    By Sharky in forum General
    Last Post: - 20th October 2006, 13:17
