18F Config fuses
Results 1 to 21 of 21
    The new 18F config directive without the double underscore only works if you use it in the .inc file. They will not work when inserted directly in your code.
    If you comment out 18F config settings in the default PBP .inc file, then insert them directly in your code, you'll have to use the older __config directive.
    Newer versions of PBP include files now have the w = -230 option to suppress the deprecated warning message MPASM spits out when it sees the older __config directive, but it still doesn't allow inserting the new directives inline.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Hey Bruce-
    Wow! Thanks for solving the problem. Reliable as ever!
    Just wish that it was easier to find documented answers to problems such as this.
    Angus Anderson
  1. A/D conversion with PIC18F67J50
    By ScaleRobotics in forum mel PIC BASIC Pro
    Last Post: - 8th May 2009, 02:48
  2. 18F4550 Bootloader enter via eeprom setting
    By bradb in forum mel PIC BASIC Pro
    Last Post: - 23rd November 2008, 00:51
  3. Error 0X0000008E when connecting a 18F2550 USB HID
    By FranciscoMartin in forum USB
    Last Post: - 16th October 2008, 18:20
  4. PortE problems (PIC18F4455)
    By RubenR in forum mel PIC BASIC Pro
    Last Post: - 12th July 2006, 16:26
  5. Installation sequence
    By Demon in forum General
    Last Post: - 11th July 2006, 04:56
