I got the whole thing to compile guys, thanks
Use:
PBP 2.46
MPLAB 7.30
Win98SE to compile
A few observations-
1) MPASM told me when compiling that I had dual specifications for the config file. I did have config statements in the source file. By REM'ing the config statements in the PBP 18F452.INC file, it compiled fine with MPASM
Why the dual sensing? Surely the assembler will check if there is a config statement in the source, and if not, use the .INC file to set a default? Why pick up both?
2)What compiled with 7607 bytes on a 16F877A using the PM compiler actually compiles to 12477 bytes using the MPASM compiler. I can't believe that I have lost 1/2 of what I hoped to gain in code space by converting to an 18F device - that is, 4K. Is this normal?
