Best way to store text in a pic
Results 1 to 4 of 4
    Bombay, India
    Smile
    This is how I do it
    prn_SetDate:       PokeCode "Date changed",0
    prn_SetTime:       PokeCode "Time changed",0
    prn_LogPrinted:    PokeCode "Log printed",0
    prn_SafeClosedByMaster: PokeCode  "Key interlock cleared by master",0
    GetAddress macro Label, Wout       ; Returns the Address of a Label as a Word
        CHK?RP Wout
        movlw low Label
        movwf Wout
        movlw High Label
        movwf Wout + 1
    Address         var     word
    '----snip------
        ' This is how to use it
        ' Prt_puts uses the Variable Address to print the contents pointed at by it
        @ GetAddress _prn_SetDate, _Address ;macro from this site
        gosub Prt_puts                                 ; put the string to printer
    '----snip------
    ' Print an ASCIIZ string
    ' Input - Address points to the string
    Prt_puts:
      repeat
        peekcode Address, gr[0]                   ' gr[0] is a byte sized user register
        if gr[0] then
          gosub Prt_putc                             ' print 1 character
          Address = Address+1
      until gr[0]=0                                     ' print till end of string '0'
    Hope this helps
    Variant of the above
    STRINGS - How to store and retrieve strings in Code Space
    http://www.pbpgroup.com/modules/wfse...p?articleid=10
    which is also explain/discussed + few variant & mods
    Embedded Strings in your Code Space
    http://www.picbasic.co.uk/forum/show...ight=codespace
  1. SMS via pic
    By kenandere in forum GSM
    Last Post: - 10th March 2010, 10:00
  2. Replies: 67
    Last Post: - 8th December 2009, 02:27
  3. assembly in Pic
    By lerameur in forum Off Topic
    Last Post: - 1st May 2008, 20:06
  4. Help with sending text file from pic
    By isaac in forum Serial
    Last Post: - 15th August 2006, 20:01
