Zero crossing output with HWPM
Results 1 to 5 of 5
    Default Additional output with PWM
    The PWM will be normal but I want to fire separate digital outputs at zero crossing and max to sync up an external device.
    Is there a way to access the PWM registers directly, so I can fire these outputs based on their value?
    Feb 2005
    Kolkata-India
    Default Yes of course
    In PBP all (almost) the registers of the PIC MCU are accessible. The 2 LSB of the PWM are in the CCPCON(CCP1CON/CCP2CON) bit 5,4. The MSBs are directly accessible using the CCPR1L and CCPR2L.
    Sougata
    Smile Thank you
    Exactly what I was looking for. Thank you
  1. Bit Banging input to output on PIC16F876A
    By Bronurstomp in forum mel PIC BASIC Pro
    Last Post: - 26th June 2008, 20:50
  2. Serious Serial Situation Setbacks...
  3. Using LEDs as light sensors
    Last Post: - 30th December 2006, 23:19
  4. HSEROUT Newbie question/problem
    By Mark Scotford in forum mel PIC BASIC Pro
    Last Post: - 11th July 2006, 15:44
  5. error on compiling
    By parker in forum mel PIC BASIC Pro
    Last Post: - 16th June 2005, 15:31
