large & efficient electro magnet
Results 1 to 14 of 14
    Jan 2007
    Default large & efficient electro magnet
    Im building pulse motor, after construction small scale I decide to make large one, I will hand wound 2 km of thin wire to create electromagnet it a lot of wire to do manually so I want to make most efficient magnet from first time.
    The question is what is more important , coil bobbin length or thickness , should my coil be tall or short and fat, I will use 1 inch diameter iron rod.
    Formula from wiki
    B = (N I)/L
    * N is the number of turns of wire around the electromagnet
    * I is the current in amperes
    * L is the length of the magnetic circuit
    * B is the magnetic field in teslas
    show that fat coil will be more efficient (less L) but personal experiment show opposite result , long coil stop moves compass needle from 7 cm when thick coil twice shorter of same wire length stop move needle only from 4 cm away
    Another question should I wind many wires together and then connect them (in series or parallel) or single wire is more efficient
    maybe picture will explain better what I mean.
    All you ever wanted to know...
    http://info.ee.surrey.ac.uk/Workshop...ils/force.html
    Wiki I would not trust.
    Jan 2007
    Thank you that was very useful information
    just one more question, can I have an advice how to safety connect digital scope to read the coil, I have 100x probes but they home made and really noisy so I want to use 10x one and voltage might exceed them and I don't know what will happen to scope then.
    You will destroy it. A coil with the kind of inductance you are winding will probably have an emf of a few kV... most modern scopes only have a 50v tollerance.
    Use your probe set to 10:1 and use a Resistor divider chain of another 10:1. If the Bottom Resistor is 1M it won't load the circuit. That should give you a 5kV operational tollerance.
    Italy
    Pulse motor evolution. (Moto-perpetuos made in Seattle USA).
    (Make sure your PC speakers are on).
    Best regards,
    Luciano
    Yeah, right... more like moto-preposterous...
    Would be more meaningful if he showed CURRENT-IN versus CURRENT-OUT as well as the voltage which on it's own is irrelevant.
    What he's trying to make you believe is that his Power-Input, less frictional losses, less conversion losses, less electrical losses, is still a NET GAIN?
    christopherh's Avatar
    christopherh Guest
    Default Re: large & efficient electro magnet
    I learnt so much through these threads. thanks every one for enhancing my knowledge by sharing your posts.
  1. store/display very large numbers (700000)
    By ttease in forum mel PIC BASIC Pro
    Last Post: - 18th March 2007, 23:08
  2. large file transfer petween pics
    By Ron Marcus in forum mel PIC BASIC Pro
    Last Post: - 3rd July 2005, 18:04
