PBC & MPLab
Results 1 to 2 of 2
Thread: PBC & MPLab
    bluumax's Avatar
    bluumax Guest
    Default PBC & MPLab
    Hi. I can't get PBC to reg w/ MPLab.
    WinXP, PBC 2.43, MPLab ver8.
    I ran PBregister.bat added ...;C:\PBC;C:\Program Files\Microchip\MPASM Suite.
    Which are correct.
    Restarted, can't get it to work.
    Have been writing mostly in assembly for years, but wanted to start using bas again.
    Hope someone can help.
    Thanks, Shawn.
    I assume you followed this instruction.
    http://www.melabs.com/support/mplab.htm
    Did you try setting the language tool suite in MPLAB? Have to ask.
    I have not upgraded to MPLAB8 yet. Have you check the path to MPASM?
    I bet the problem is with *.bat file. Run as admin?
    The only problem I have had is with the *.bat file. But I use linux.
  1. Upgraded to MPLAB IDE 8.14 and now I'm stuck
    By BlueHairBob in forum General
    Last Post: - 20th August 2008, 02:15
  2. pbp --> mplab broken again
    By kenif in forum mel PIC BASIC Pro
    Last Post: - 11th December 2006, 19:57
  3. Microcode Studio MPLAB support
    By jbpaul in forum General
    Last Post: - 27th November 2006, 07:55
  4. melabs USB programmer into MPLAB?
    By jocovo in forum General
    Last Post: - 10th November 2006, 17:58
  5. MPLAB ICD ver 1 & 16F628A
    Last Post: - 26th February 2005, 01:44
