Fatal error?
Results 1 to 3 of 3
Thread: Fatal error?
    Default Fatal error?
    Hey guys, I'm having some compiler issues... When it gets to the assembly stage, it comes up with the following error: Fatal : [301] out of memory
    I'm not trying to compile a huge chunk of code, either. I tried compiling another code example of approximately the same length and it works fine.
    Any ideas? I don't know what to make of it...
    Thanks!
    Maybe ...
    http://www.melabs.com/faq/02083357.htm
    or if it actually makes it to MPASM, is there any ASM in your program??
    Thanks, I'll look into that. There isn't any assembler in it. On a side note, it seems to only affect code containing ADC. I tried compiling one of the sample ADC programs and it does the same thing, but it seems to compile most other things just fine.
  1. Loop with two motor and 2 sensors
  2. Optimizing DIV
    Last Post: - 22nd September 2008, 04:58
  3. pbp245 compliation error
    By Woodzy in forum mel PIC BASIC Pro
    Last Post: - 25th July 2006, 05:59
  4. 16F88 Compile error
    By Toley00 in forum mel PIC BASIC Pro
    Last Post: - 2nd November 2005, 00:22
  5. Compiler/Assembler Error
    By LT_Pic in forum General
    Last Post: - 21st July 2005, 09:47
