HELP! Serial input between Pic and PC (urgent)
Results 1 to 35 of 35
    For starters, you are using already 2 seconds delay inthe loop. I am sure you are going to loose many data between this time spent on waiting.
    Please provide more info on the program at PC side. What is sending and at what rate?
    Also == has to be replaced by = and the () are not needed here.
    One recommendation would be to have the PC send a start character like : and PIC wait for this character and then grab the next one.
    like this:
    serin PORTA.3,T9600,[":"],B0
    Also ged rid off the pause commands.
    Nov 2007
    Hello,
    The setting for the hyperterminal are:
    bit per second = 9600
    Data bits = 8
    Parity = None
    Stop bits = 0
    Flow Control = 0
    I need to send the character form pc to pic, say i type the 1 into the hyperterminal then the led on the pic side will on %00010001
    The code as you wrote it will respond only to characters "A" to "F" and only if you have caps lock!
    1, 2, 3 etc are coded as binary in your program, not ASCII. You have to use even for them the " ", e.g. "1", "2" etc.
    Also as I have told you on the previous post, at least the first delay should go away.
    A very good example can be found here:
    http://www.picbasic.co.uk/forum/show...hlight=parsing
    and a bit confusing here:
    http://www.picbasic.co.uk/forum/show...ghlight=Serial
    Nov 2007
    Hello,
    1. Mr Ioannis, thanks for your reply. I was modified my program but still have no result.
    Source Code:
    Define OSC 10
    include "Modedefs.bas"
    ADCON1 = 6
    TRISA = %111000
    TRISB = 0
    B0 var byte
    PORTB = 0
    serin PORTA.3,T9600,B0
    if B0="1" then PORTB = %00010001
    if B0="2" then PORTB = %00100010
    if B0="3" then PORTB = %00110011
    if B0="4" THEN PORTB = %01000100
    If B0="5" THEN PORTB = %01010101
    if B0="6" then PORTB = %01100110
    if B0="7" then PORTB = %01110111
    if B0="8" then PORTB = %10001000
    if B0="9" THEN PORTB = %10011001
    if B0="A" THEN PORTB = %10101010
    if B0="B" then PORTB = %10111011
    if B0="C" then PORTB = %11001100
    if B0="D" then PORTB = %11011101
    if B0="E" THEN PORTB = %11101110
    if B0="F" THEN PORTB = %11111111
    GOTO MAIN
    2. What is the difference between T9600 and N9600? If I'm using a max232 IC then which type should i use?
    With SERIN and a MAX232 you need to use T9600.
    Try Sending Data fom your PIC to your PC to see what happen.
    I feel some hardware and configuration fuse problem here...
    You may also try with DEBUG/DEBUGIN...
    Feb 2005
    Kolkata-India
    Default Consider using the USART
    Since you are using a PIC with hardware serial peripheral I suggest you use the hardware port if (your port pins are not used up). Even if your global interrupt is not set to handle interrupts (INTCON.7) the hardware flags inside the PIC always responds to an interrupt event. So you can just
    1. Poll the bit PIR1.5 (RCIF) for a 1 and if yes then
    2. Read the RCREG register to your own variable MySerialData = RCREG
    (Note the interrupt flag RCIF gets cleared once you read the data)
    3. Do your stuff
    4. Go back to the polling.
    Important to not that while you are processing and data can be grabbed by the module but if it is flooded again with data and you have not read the RCREG register then the overrun bit would be set which can be cleared by resetting and setting the CREN (continuos receive enable) bit.
    With Mister_e's PICMULTICALC utility configuring the registers for the hardware USART peripheral should not be any problem.
    Sougata
    May be the ADCON1=6 must be =7 ?
    I am not familiar with the A version of the 877. Steve?
  1. Send binary file to pic over pc serial port
    Last Post: - 3rd May 2011, 14:47
  2. Replies: 11
    Last Post: - 12th July 2008, 03:36
  3. interfacing to the pc serial port
    By kelangfei in forum General
    Last Post: - 7th October 2007, 23:35
  4. High Speed Serial Comm PC - PIC and PIC - PIC
    By manumenzella in forum mel PIC BASIC Pro
    Last Post: - 16th January 2007, 22:55
  5. Replies: 5
    Last Post: - 20th March 2006, 02:34
