HELP! Serial input between Pic and PC (urgent)
Results 1 to 35 of 35
Threaded View
  1. #27
    Nov 2007
    Hi Dave,
    1. The attachment is my circuit diagram, pls comment to me if there are something wrong.
    2. Source Code:
    Define OSC 10
    include "Modedefs.bas"
    ADCON1 = 7
    TRISA = %010000 'RA4 as serial input, RA3 as serial output
    TRISB = 0 'PortB used to ON the LED
    CHAR var byte
    PORTB = 0
    SERIN PORTA.3,T9600,CHAR
    PORTB = CHAR
    SEROUT PORTA.3,T9600,[CHAR,10] 'I used hyperterminal to received the data
    'that sent to pic
    GOTO MAIN
    3. I was try to change the value of OSC but still get the same result. For Example: when i sent "1" from hyperterminal to pic but the result that returned to hyperterminal is " ' " then the result on LED is "11111010". I was checked the ASCII table, the result is not same with the data i sent.
  1. Send binary file to pic over pc serial port
    Last Post: - 3rd May 2011, 14:47
  2. Replies: 11
    Last Post: - 12th July 2008, 03:36
  3. interfacing to the pc serial port
    By kelangfei in forum General
    Last Post: - 7th October 2007, 23:35
  4. High Speed Serial Comm PC - PIC and PIC - PIC
    By manumenzella in forum mel PIC BASIC Pro
    Last Post: - 16th January 2007, 22:55
  5. Replies: 5
    Last Post: - 20th March 2006, 02:34
