ADC problem :(
Results 1 to 12 of 12
Thread: ADC problem :(
    Sep 2007
    Okey the code look like this now:
    Define	LOADER_USED	1
    Define  LCD_DREG        PORTD
    Define  LCD_DBIT        8
    Define  LCD_RSREG       PORTE
    Define  LCD_RSBIT       0
    Define  LCD_EREG        PORTE
    Define  LCD_EBIT        1
    ' Define ADCIN parameters
    Define	ADC_BITS	   8	' Set number of bits in result
    Define	ADC_CLOCK	   3	' Set clock source (3=rc)
    Define	ADC_SAMPLEUS  50	' Set sampling time in uS
    ad1	var	BYTE
    ad2 var	BYTE	    ' Create adval to store result
    ad3	var	BYTE
    ad4 Var BYTE
       TRISA = %11111111	' Set PORTA to all input
       ADCON1 = %00000010	' Set PORTA analog
       Low PORTE.2		    ' LCD R/W line low (W)
       'Pause 500		    ' Wait .5 second
       ADCIN 0, ad1		        ' Read channel 0 to adval
       ADCIN 1, ad2		        ' Read channel 1 to adval
      ' ADCIN 3, ad3 	        ' Read channel 3 to adval
       PWM portc.4 ,ad1,1' Send a 50% duty cycle PWM signal out Pin7 for 100 cycles
       ad1 = ~ad1
    ad2 = ~ad2
       LCDout $fe, 1
       LCDOUT "nacke:", #ad1
       LCDOUT $FE, $C0, "rygg:", #ad2
       ad4 = ad2
    Symbol delay = ad4  ' use b0 as the delay variable
    loop: high portD.0              ' turn on Q1
          pause ad4         ' wait 25 ms
          low portD.0               ' turn off Q1
          high portD.1              ' turn on Q2
          low portD.1               ' turn off Q2
          high portD.2              ' turn on Q3
          low portD.2               ' turn off Q3
          high portD.3              ' turn on Q4
          low portD.3               ' turn off Q4
       Goto    main        ' Do it forever
    The problem is that its "slow" to update on the screen now. its no "smooth" jumps its like 5-15-70-100
    (its 0 to 255)
    ofc its all about how fast i move it.
    but maybe the fastest way is just to turn it around ye?
    Sep 2007
    Ok i solved it thanks every one! The
    ad1 = ~ad1
    ad2 = ~ad2
    helped alot
    Thanks again!
  1. pic12f675 ADC problem
    By radu022003 in forum mel PIC BASIC
    Last Post: - 1st September 2009, 10:13
  2. PIC18F2423, ADC problem
    By mistergh in forum mel PIC BASIC Pro
    Last Post: - 17th March 2009, 01:31
  3. Mutliple ADC problem with PIC16F877
    By andyto in forum mel PIC BASIC Pro
    Last Post: - 3rd October 2007, 17:47
  4. ADC problem with PIC16F917
    By eetech in forum mel PIC BASIC Pro
    Last Post: - 7th March 2007, 21:22
  5. Problem reading multiple ADC ports
    By jswayze in forum mel PIC BASIC Pro
    Last Post: - 4th November 2004, 16:46
