yup, as long the OP didn't asked for a software solution and can do some hardware mods, unless you can't be wrong.
PS: 30cm de neige ici aujourd'hui![]()
Hi, Steve
For once, you have the "soft" solution ... keep on that way ....( no more guns, ... etc,etc )
Lots of LOL from le " maudit Français"
Ici, c'est Water: l'eau ...
well ad1 = 255 - ad1 make the pot "freeze" (not change number)
Any way we will try that the solution you posted before did work with the ~ but it increased to 1111111111111111 in bin. :O in other word 655xx or something like that.
Kaldurenik, I don't know how that can be? You have ad1,ad2,ad3,ad4 declared as byte variables unless you have changed them..... Using ad1 = ~ad1 if the variable is a byte should work.
Okey the code look like this now:
The problem is that its "slow" to update on the screen now. its no "smooth" jumps its like 5-15-70-100Code:Define LOADER_USED 1 Define LCD_DREG PORTD Define LCD_DBIT 8 Define LCD_RSREG PORTE Define LCD_RSBIT 0 Define LCD_EREG PORTE Define LCD_EBIT 1 ' Define ADCIN parameters Define ADC_BITS 8 ' Set number of bits in result Define ADC_CLOCK 3 ' Set clock source (3=rc) Define ADC_SAMPLEUS 50 ' Set sampling time in uS ad1 var BYTE ad2 var BYTE ' Create adval to store result ad3 var BYTE ad4 Var BYTE TRISA = %11111111 ' Set PORTA to all input ADCON1 = %00000010 ' Set PORTA analog Low PORTE.2 ' LCD R/W line low (W) 'Pause 500 ' Wait .5 second main: ADCIN 0, ad1 ' Read channel 0 to adval ADCIN 1, ad2 ' Read channel 1 to adval ' ADCIN 3, ad3 ' Read channel 3 to adval PWM portc.4 ,ad1,1' Send a 50% duty cycle PWM signal out Pin7 for 100 cycles ad1 = ~ad1 ad2 = ~ad2 LCDout $fe, 1 LCDOUT "nacke:", #ad1 LCDOUT $FE, $C0, "rygg:", #ad2 ad4 = ad2 Symbol delay = ad4 ' use b0 as the delay variable loop: high portD.0 ' turn on Q1 pause ad4 ' wait 25 ms low portD.0 ' turn off Q1 high portD.1 ' turn on Q2 pause ad4 ' wait 25 ms low portD.1 ' turn off Q2 high portD.2 ' turn on Q3 pause ad4 ' wait 25 ms low portD.2 ' turn off Q3 high portD.3 ' turn on Q4 pause ad4 ' wait 25 ms low portD.3 ' turn off Q4 Goto main ' Do it forever End End
(its 0 to 255)
ofc its all about how fast i move it.
but maybe the fastest way is just to turn it around ye?
Oki solved it thanks every one! The
ad1 = ~ad1
ad2 = ~ad2
helped alot
Thanks again!
