Timer - pause? ..?
Results 1 to 10 of 10
    Jul 2007
    Default Timer - pause? ..?
    How do you make a code work like this:
    When I push a button a timer starts and when I push it again it stops and make that time into a variabel. So I can use that time in my program something like this:
    HIGH PORTB.1
    PAUSE "The Time"
    LOW PORTB.1
    How accurate do you need it and how long will the timer run at a time?
    If you need to do other things while the timer is running then an interrupt will be needed. Search the forum for timers.
    If you want something quick and dirty and nothing else will be happening when the time is collected this idea might work for you.
    When the button is pushed goto a time loop and stay there until the button is pushed again.
    While in that loop have a pause for a certain amount of time . Count to a variable each time (T=T+1) through the loop. When you are out of the loop read the variable.
    Say the pause is 100 ms and it goes through the loop 10 times. that would equal 1 second plus execution time.
    Jul 2007
    Both includes a LCD wich make it harder to understand the code :/
    xobx, Just declare a word size variable and then pass it as the variable to the pause statement, like this:
    time var word 'time in milliseconds
    HIGH PORTB.1
    PAUSE time
    LOW PORTB.1
    Default forgive my phone formatting.
    maybe something like this? (§ indicates new line) §loop: §button portb.0,1,255,0,but1,0,loop §gettime: §pause 100 §thetime = thetime + 1 §button portb.0,1,255,0,but1,0,gettime §flash: §for blink = 1 to thetime §high portb.1 §pause 100 §next blink §low portb.1 §goto loop
    Default thetime var word
    max number of pauses will be 65535. so with pause 100 max time will be 6553.5 seconds or just under 110 mins. for longer times use a longer pause, for better accuracy use a smaller pause. it would also need a line in gettime to make sure it doesn't overflow.
    Thumbs up now that I'm home
    This will be more readable:
    loop:
    gettime:
    flash:
    high portb.1
    next blink
    low portb.1
    goto loop
    Jul 2007
    Ok but I doesnt understand this line :/
    PBP Pro manual, page 47.
    All parameters explained
  1. Delayed output 10 secs
    By lilimike in forum mel PIC BASIC Pro
    Last Post: - 14th October 2011, 06:28
  2. Old and beyond help ?
    By DavidFMarks in forum mel PIC BASIC Pro
    Last Post: - 11th December 2008, 15:23
  3. Replies: 11
    Last Post: - 12th July 2008, 02:36
  4. Fade out LEDs question
    By Sam in forum mel PIC BASIC Pro
    Last Post: - 22nd June 2008, 10:50
  5. Help Quick Need to make code smaller
    By Programmednew in forum mel PIC BASIC Pro
    Last Post: - 25th January 2005, 03:46
