Diseqc control anyone ?
Results 1 to 12 of 12
    Default Diseqc control anyone ?
    Hi
    I was wondering if someone has already made a project to control a 2 or 4 way diseqc
    antenna switch
    As i dont want to reinvent "the wheel" maybe someone can share his project
    France
    Default Re: Diseqc control anyone ?
    HI ... RF solution ..
    It seems that nobody has done something on this subject (DISECQ commands from a PIC)
    Do you find "a solution" ?
    thanks
    Francois F1CHF
    Oct 2009
    I doubt you would get a reply unless the OP still receives notifications as his last post was back in 2014.
    I have done it once using soundcard, not PBP
    France
    Thnks for the replies
    Yes it seems that nobody has done something via a PIC solution
    I found some example but with Arduino.
    Objective is to have a Disecq transmitter not for sat station or LNB
    but to program some switchs or drive (and control) an Antenna rotator !
    the hardware link could be an ordinary coaxial (power and 22 Khz Disecq)
    as usual, it is a project ... number xx ... hi !!!
    Francois F1CHF
    There are some speciality devices, which can do that.
    France
    some details please ....
    thanks
    Am I correct in that "all it is" a 22kHz carrier modulated 0.5ms ON, 1.0ms OFF for a logic one and 1.0ms ON, 0.5ms ON for logic zero? How critical is the 22kHz and how critical is the on/off times?
    Doesn't sound too hard to do with a PIC, much like a IR remote. The CCP moudle can generate a 22kHz tone which you can modulate with software by simply truning the signal on and off. You need external filter and attenutation+buffer to get the 0.65V peak-to-peak sinewave carrier.
    With that said, I've got no experience with Diseqc, this is the firts time I've looked at it.
    I think this PDF has enough information to create a PBP encoder/decoder. Like Henrik said, it looks a lot like IR remote control format. Very low bit rate.
    http://www.eutelsat.com/files/contri...s/bus_spec.pdf
    France
    yes you are right, seems similar to IR protocol
    Henri what do you mean bye "The CCP moudle can generate a 22kHz"
    there are two options : External 22 Khz generator or if the pic is free, have a process to do that ..
    They said "nominal 22 kHz (±20 %)" so a simple NE555 could be OK
    I must make a prototype, as I have some Disecq LNB switch to test, I will be able to verify
    problem is to fond some more time !
    This was the first objective of my first message "already done by somebody" hi ...
    Francois
    The CCP module can be setup to generate a 22kHz squarewave. Use an external filter to turn it into a sine and attenutate it 650mV, then use a rail-to-rail OP-Amp to buffer it and (I'm guessing) AC-couple it onto the coax. Then it's just a matter of turning the CCP module on and off with the correct timings to get the signal out.
    I don't know, you may be able to just attenuate and AC-couple the square wave directly onto the cable.
    Do you have a PIC already that you wanted to use?
    Devices like this can be used for this task:
    http://www.ebay.com/itm/SatLink-WS-6...0AAOSwc1FXbKjD
    Also, as I said, I've generated diseqc commands in sound editor. Then recorded to phone, and built simple circuit to allow it to be transferred to switch.
  1. diseqc rotor control
    Last Post: - 3rd February 2010, 17:32
  2. How do I give a radio control car autonomous control
    By Kenjones1935 in forum General
    Last Post: - 17th January 2010, 16:40
  3. pt2258+16f877 how can i use for 5.1 volume control ?
    By whyliving in forum mel PIC BASIC Pro
    Last Post: - 26th January 2008, 18:51
  4. Control unlimited servos at the same time
    By mrx23 in forum mel PIC BASIC Pro
    Last Post: - 19th September 2006, 15:14
  5. Control RC servo via Parallax Servo Control
    Last Post: - 17th September 2005, 09:18
