Yup and i missed it...
What capacitor value did you put on your Crystal? 15-22pf?
what happen if you remove the MAX232, and use inverted mode for your baudrate???
With the MCLR_ON, it mean you use MCLR, so i hope this pin is tied to Vcc?
Clean psu, decoupling caps here and there?
Did you also tried with the internal OSC?
I don't see anything wrong in the code...
