16F877A problem: "coupled" digital values
Results 1 to 17 of 17
    C / Java is not as intimidating as it first looks.
    About six months ago I purchased two Java books. I am starting to make a little progress. Now my biggest problem is finding time to work on it. The IDEs like NetBeans just made it more confusing. Every one seems to have a different method. Now I am using gedit and compiling from the command line.
    T.Jackson's Avatar
    T.Jackson Guest
    Personally, I just compile at console level. Typically I'll have two instances, 1 for compiling and the other for running / testing. As you may or may not be aware, java files need to be launched at console level unless you create a jar file with the inclusion of a manifest in order to be able to execute the program at OS level (double click to run) - which is your typical Windows-based executable. Sadly, this is as about as good as it gets for a standalone application with Java.
    I got the manifest and jar things figured out. Those were some of the things the books did not cover well. Google to the rescue.
    The thing I like about java and the reason I want to learn it is its cross platform capability.
    T.Jackson's Avatar
    T.Jackson Guest
    Java is king for that. No time lost learning Java, it uses the same syntax as C, it's object oriented, performance wise it's arguably almost par with C, will never be "as" quick because of the latency of the (VM) - Virtual Machine. I did a bit of a comparison test with Java & BASIC a few months ago - Java puts BASIC to shame (up to 20 times more efficient)
  1. Average Values and digital filter ...
    By jorge in forum mel PIC BASIC Pro
    Last Post: - 24th April 2010, 12:29
  2. Problem displaying data from GPS module & using 16f877a
    Last Post: - 15th April 2010, 10:27
  3. Problem with 16F877A but not with 16F876A
    Last Post: - 16th May 2008, 14:18
  4. 16F877a PORTA ADC and digital help
    Last Post: - 8th February 2008, 18:44
  5. 16F877A serin problem with baud rate 19200
    By leemin in forum Serial
    Last Post: - 31st July 2005, 09:45
