Modulate IR
Results 1 to 4 of 4
Thread: Modulate IR
    Quote Originally Posted by Forkosh View Post
    What is the code I can use to modulate IR
    I am using an IR LED and IR phototransistor to detect a line
    How can I modulate that?
    I am using the PIC 16F616 @ 4mhz
    Thank You
    Use the HPWM to generate the modulation; change the status of the HPWM pin to an output when you want a '1' to be transmitted, and change it to an input for a '0'. This way, you can achieve the IR transmission with only 1 pin, and no external gating circuitry.
    BTW, if you are modulating the IR signal, you'd get much better results using a 3 pin IR demod. module.
    Anand Dhuru
    something 'round this thread should give some idea
    http://www.picbasic.co.uk/forum/showthread.php?t=3057
  1. Replies: 17
    Last Post: - 12th April 2014, 03:17
  2. PIC16F877A pwm use for IR transmission
    By mcbeasleyjr in forum General
    Last Post: - 11th July 2009, 19:51
  3. Plz help in completing RC-5 IR remote lamp dimmer project
    By vu2iia in forum mel PIC BASIC Pro
    Last Post: - 3rd April 2008, 09:44
  4. PIC10F200 Automated IR Light Switch
    Last Post: - 3rd May 2007, 12:40
  5. how to get pic to pic communication
    By kinsiro in forum mel PIC BASIC Pro
    Last Post: - 30th August 2005, 18:12
