Serial data problem
Results 1 to 12 of 12
    Jun 2007
    Mansfield, UK
    Im sure the PC software is setup correctly. I can change the address of the chip fine (that only takes 2 bytes). The PC software works on other chips too.
    I think im gonna try a different aproach. Im going to buffer all the incoming data as fast as i can then deal with it every half cycle
    Edit: Yes, 18 bytes for control. 2 bytes for an address reset. When sending 18 bytes it misses out 1-3 bytes
    Jun 2007
    Mansfield, UK
    I just tried some test code out
    'The main loop
    loop:
        'Check for serial data
        if pir1.5=1 then 'Check if there is any serial data
            while pir1.5 'Loop through all the data
                indata=RCREG 'Get a byte
                select case indata
                    case 255 'Reset the buffer
                        recpos=0
                    case else
                        if recpos<17 then
                            inbuffer(recpos)=indata
                            recpos=recpos+1
                            high porta.1
                end select
            wend
            if rcsta.1=1 then
                rcsta.4=0
                rcsta.4=1
    goto loop
    Now, that code *should* wait for a 255. When it gets it it resets recpos to 0. Each byte after that should end up in InBuffer until recpos=17. At that point a light should turn on (porta.1)
    The reset part does seem to be working but not all the bytes arrive. The light wont come on until i send another 1-3 bytes.
    I should point out im not using the MAX232 chip because they havnt arrived yet but instead i linked into one of Matts boxes which has an alternative solution. I cant see why that would cause a problem but ive just found out that when i set the address it gets set to 1 less than what i actually set it to
    Jun 2007
    Mansfield, UK
    Woo. Its all working Ive only got 1 output working at the moment though. Ive got to put a loop in to handle all outputs and ive got to put the set address code back in but as it is the attached code is working perfectly.
    I only have 1 small problem with it. If i send data too fast then the light flickers slightly. Not enough to be annoying but i doubt the PC would ever send commands that fast anyway
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 05:47
  2. Read/Write Problem
    Last Post: - 10th February 2010, 02:51
  3. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 03:21
  4. LCD + bar graph
    Last Post: - 5th October 2005, 15:50
  5. Sinus calculating !
    Last Post: - 29th November 2004, 00:56
