some pause/pauseus may screwup things here.
How do you send the data?
What's the format?
what is the expected results?
What's the format?
The PC sends chr(255) chr(chipID) chr(brightness1)... chr(brightness16)
When a 255 arrives the recpos is set to 16. That means it has to wait for an address. If the address matches the chips address then recpos is set to 0 which means 16 bytes are about to come in. It then counts up to 15 as they arrive. Once at 15 it should stop and wait.
If pauses can cause problem then that could be it. I only check for data once every half cycle. Should i check more often? I can check upto 100 times every half cycle. For testing its set to 10 incase you were wondering
which PC software do it?
Are you sure it's 9600 baud and not 250,000 bauds?
So basically it's always a 1+1+16 = 18 data stream?
If so, did you tried with a HSERIN loop? just for debuggig purpose.
Code:DataByte VAR BYTE[18] HSERIN [STR DataByte\18] If DataByte[0]= 255 then DoSomething
Im sure the PC software is setup correctly. I can change the address of the chip fine (that only takes 2 bytes). The PC software works on other chips too.
I think im gonna try a different aproach. Im going to buffer all the incoming data as fast as i can then deal with it every half cycle
Edit: Yes, 18 bytes for control. 2 bytes for an address reset. When sending 18 bytes it misses out 1-3 bytes
I just tried some test code out
Now, that code *should* wait for a 255. When it gets it it resets recpos to 0. Each byte after that should end up in InBuffer until recpos=17. At that point a light should turn on (porta.1)Code:'The main loop loop: 'Check for serial data if pir1.5=1 then 'Check if there is any serial data while pir1.5 'Loop through all the data indata=RCREG 'Get a byte select case indata case 255 'Reset the buffer recpos=0 case else if recpos<17 then inbuffer(recpos)=indata recpos=recpos+1 else high porta.1 endif end select wend if rcsta.1=1 then rcsta.4=0 rcsta.4=1 endif endif goto loop
The reset part does seem to be working but not all the bytes arrive. The light wont come on until i send another 1-3 bytes.
I should point out im not using the MAX232 chip because they havnt arrived yet but instead i linked into one of Matts boxes which has an alternative solution. I cant see why that would cause a problem but ive just found out that when i set the address it gets set to 1 less than what i actually set it to
Woo. Its all workingIve only got 1 output working at the moment though. Ive got to put a loop in to handle all outputs and ive got to put the set address code back in but as it is the attached code is working perfectly.
I only have 1 small problem with it. If i send data too fast then the light flickers slightly. Not enough to be annoying but i doubt the PC would ever send commands that fast anyway
