Serial data problem
Results 1 to 12 of 12
    Jun 2007
    Mansfield, UK
    Hmm. I am running that too but only once all the data i want has been received. I dunno.
    Ive uploaded the code. Sorry its so long and confusing.
    some pause/pauseus may screwup things here.
    How do you send the data?
    What's the format?
    what is the expected results?
    Jun 2007
    Mansfield, UK
    The PC sends chr(255) chr(chipID) chr(brightness1)... chr(brightness16)
    When a 255 arrives the recpos is set to 16. That means it has to wait for an address. If the address matches the chips address then recpos is set to 0 which means 16 bytes are about to come in. It then counts up to 15 as they arrive. Once at 15 it should stop and wait.
    If pauses can cause problem then that could be it. I only check for data once every half cycle. Should i check more often? I can check upto 100 times every half cycle. For testing its set to 10 incase you were wondering
    which PC software do it?
    Are you sure it's 9600 baud and not 250,000 bauds?
    So basically it's always a 1+1+16 = 18 data stream?
    If so, did you tried with a HSERIN loop? just for debuggig purpose.
    DataByte VAR BYTE[18]
    HSERIN [STR DataByte\18]
    If DataByte[0]= 255 then DoSomething
    Jun 2007
    Mansfield, UK
    Im sure the PC software is setup correctly. I can change the address of the chip fine (that only takes 2 bytes). The PC software works on other chips too.
    I think im gonna try a different aproach. Im going to buffer all the incoming data as fast as i can then deal with it every half cycle
    Edit: Yes, 18 bytes for control. 2 bytes for an address reset. When sending 18 bytes it misses out 1-3 bytes
    Jun 2007
    Mansfield, UK
    I just tried some test code out
    'The main loop
    loop:
        'Check for serial data
        if pir1.5=1 then 'Check if there is any serial data
            while pir1.5 'Loop through all the data
                indata=RCREG 'Get a byte
                select case indata
                    case 255 'Reset the buffer
                        recpos=0
                    case else
                        if recpos<17 then
                            inbuffer(recpos)=indata
                            recpos=recpos+1
                            high porta.1
                end select
            wend
            if rcsta.1=1 then
                rcsta.4=0
                rcsta.4=1
    goto loop
    Now, that code *should* wait for a 255. When it gets it it resets recpos to 0. Each byte after that should end up in InBuffer until recpos=17. At that point a light should turn on (porta.1)
    The reset part does seem to be working but not all the bytes arrive. The light wont come on until i send another 1-3 bytes.
    I should point out im not using the MAX232 chip because they havnt arrived yet but instead i linked into one of Matts boxes which has an alternative solution. I cant see why that would cause a problem but ive just found out that when i set the address it gets set to 1 less than what i actually set it to
    Jun 2007
    Mansfield, UK
    Woo. Its all working Ive only got 1 output working at the moment though. Ive got to put a loop in to handle all outputs and ive got to put the set address code back in but as it is the attached code is working perfectly.
    I only have 1 small problem with it. If i send data too fast then the light flickers slightly. Not enough to be annoying but i doubt the PC would ever send commands that fast anyway
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 05:47
  2. Read/Write Problem
    Last Post: - 10th February 2010, 02:51
  3. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 03:21
  4. LCD + bar graph
    Last Post: - 5th October 2005, 15:50
  5. Sinus calculating !
    Last Post: - 29th November 2004, 00:56
