bootloader Freqout problems
Results 1 to 3 of 3
    Dec 2007
    Default bootloader Freqout problems
    Hello
    i have a program use Serial Communitacion, LCDout, and Freqout commands, and i like use a bootloader, but i have problems because the PIC not work, first i have problems with the LCD, cannot see any caracter in the device, but with the next post , i am fix the problem
    http://www.picbasic.co.uk/forum/showthread.php?t=1318
    now i like use the FREQOUT command, all work fine, but when the program skip to this command the PIC not work, not generate the sound and they restart, when i am use the program without bootloader all work fine, the hardware is ok, i am use a 16F876A at 20MHz, is possible help me
    thanks
    When you're using the bootloader, make sure you have DEFINE LOADER_USED 1 at the top of your code. The syntax must be exact and in CAPITAL letters, unless, yes it may give you some weird results.
    Now, did you tried with a simple led Blink?
    Does the Bootloader return any error messages?
    Did you use the same schematic as stated in the MCS help-file?
    Are you using Mecanique bootloader or another one?
    Dec 2007
    thanks Mister E for reply
    my circuit work , but when i am use the command Freqout or Dtmfout the program restart, the other function work fine, Lcdout, serin2/serout2 , in the begin, not working the LCDout function, but making the change in the LIB file work without problems, maybe you know i need make other change in the LIB file for the command Freq and Dtmf work
    Thanks for your time
  1. PIC18F4680 bootloader
    By vinyl_theif in forum General
    Last Post: - 29th January 2009, 18:45
  2. 18F4550 Bootloader enter via eeprom setting
    By bradb in forum mel PIC BASIC Pro
    Last Post: - 23rd November 2008, 00:51
  3. Max/232 Bootloader problems - Schematic attached...
    By rossfree in forum mel PIC BASIC Pro
    Last Post: - 4th May 2007, 16:54
  4. USBDemo with Bootloader
    By vacpress in forum USB
    Last Post: - 25th January 2007, 23:29
  5. Bootloader Problems
    Last Post: - 11th February 2005, 18:51
