First of all, I want to say hello to everybody in these forums. Thanks for giving some of your time to helping out people.
I have an Issue with all the pics I program. I've read that when you work with interrupts in PBP, when they are activated, they wait for the last command to finish before they begin.
That is, if you are in a 50 second pause when it happens, you'll have to wait for the pause to end before the interrupt becomes active.
To avoid this all you have to do is to use the For..next command. Here is where I have trouble.
When I do:
It pauses exactly for 1 second, but when I try to do the same using for...next:
for b0 = 0 to 1000
pause 1
next b0
It doesn't pause for 1 second, it speed up and pauses for like 0.3 seconds. I've tried everything but nothing fixes this, I've tried with several pics and they all have the same problem.
By the way, I use them in Internal oscillator mode but I also tried using a 4 mhz crystal and it happened again.
thanks again!
