Anyone using a reliable wireless connection?
Results 1 to 5 of 5
    Feb 2004
    Michigan, USA
    Default Anyone using a reliable wireless connection?
    Looking for a simple wireless solution to connect upto 12 remote pics to a central "server" pic via a wireless connection. Environment is household with one pic being located outside for sending weather info to the "server." Interior pics will be controlling servos for opening and closing heating vents. Distances could be up to a couple hundred feet through walls etc.
    Sep 2003
    Vermont
    If you are going through walls, the Radiotronix Wi.232 transceivers are great. They transmit at 900 MHz, with about 20 mW of RF at the antenna The connection is RS232 at any baud rate up to 115Kbaud. With a little bud of an antenna, I was getting 800 feet. The new FHSS versions are more powerful, but more expensive. I am using the 1/4 watt modules for a 2 mile link up a mountain with a solar powered weather station. I figger 10 miles LOS on these gems!
    Ron
    Jun 2006
    California
    The Maxstream development kit is well worth the investment. With the software you can walk around and test all your locations for receive signal level. That way you can determine which module to buy, the best place for the master or if you need a repeater. There is lots of support on the internet for the series 1 modules. You will need an adapter for the 2mm connector, got mine off of eBay and 3.3 VDC.
    http://www.maxstream.net/products/xb...kit-zigbee.php
    Feb 2004
    Michigan, USA
    Thanks for all the responces guys! Good stuff as always.
  1. Reliable wireless data transfer
    By dhouston in forum Code Examples
    Last Post: - 20th November 2009, 17:56
  2. Reliable RS232 Wireless
    By koossa in forum General
    Last Post: - 2nd April 2009, 10:48
  3. CO2 MG811 sensor connection
    By elektoro2009 in forum mel PIC BASIC Pro
    Last Post: - 8th May 2008, 01:49
  4. Wire worked by not wireless
    By mankan in forum General
    Last Post: - 22nd June 2006, 15:57
  5. PIC 2 PIC wireless connection
    By MegaADY in forum General
    Last Post: - 24th June 2004, 02:46
