String Seperation
Results 1 to 9 of 9
    Jun 2005
    Up the bush, Western Plains, NSW Au
    Unless I got the string wrong and it is EXACTLY "t=00 b=000 r=00 st=00000 sp=00000"
    Then I would try something like:
    SERIN2 1,N2400,[SKIP2, DEC 2 T, SKIP 3, DEC3 B, SKIP 3, DEC2 R, SKIP 4, DEC5 ST, SKIP 4,DEC5 SP]
    So, that should skip the "t=" grab the 00 into T, skip the " b=" grab the 000 into B, skip the " r=" grab the 00 into R, skip the " st=" grab the 00000 into ST, skip the " sp=" grab the 00000 into SP
    Once again the numerical sizes would apply as would the experimenting.
    Anyway, that's where I would start playing.
    Peter Moritz.
    New South Wales,
    Australia.
    SKIP is good but the Serin2 must be well synchronized at the beginning of the transmision.
    CASE Else the variables will me messed up!
    Is there a start sentinel before the "t=00 b=000 r=00 st=00000 sp=00000" so that a WAIT modifier can be used?
    Mar 2006
    Pennsylvania, USA.
    Ioannis,
    I was assuming that not all of the bytes would be in ascii, I have a device that I communicate with that sends ascii labels like "b=" and then sends hex values as the variables change. That's why I suggested that he might want to send the buffer[3] byte out to an lcd, just to make sure. I know I went nuts testing with hyper-terminal, because it kept taking the hex values and converting them to ascii characters and printing out nonsense.
    Jerry.
    If your oscilloscope costs more than your car...
    Quote Originally Posted by b1arrk5 View Post
    Yes, I understand what you mean... 8-)
  1. How about String Variables?
    By mytekcontrols in forum PBP Wish List
    Last Post: - 20th January 2015, 13:53
  2. How to convert HEX Value as formatted BIN String ?
    By Robson in forum mel PIC BASIC Pro
    Last Post: - 19th August 2007, 03:16
  3. Visual Basic 6 & Access 2000
    By Demon in forum Off Topic
    Last Post: - 7th September 2006, 05:39
  4. String Parsing
    By eoasap in forum mel PIC BASIC Pro
    Last Post: - 18th February 2006, 18:20
  5. Message String Table using Readcode
    By mytekcontrols in forum Code Examples
    Last Post: - 11th July 2005, 00:17
