What am I doing wrong?
Results 1 to 7 of 7
    Sep 2005
    Campbell, CA
    Default What am I doing wrong?
    I have the simplest piece of code that I have probably ever written, but it still doesn't work. The code is as follows, and is supposed to flash a LED connected to PortF.1 The LED refuses to flash.
    Chip is 18F66J60
    Crystal is 25MHz (yes, I know my flash rate will be off)
    Watchdog timer is OFF
    Oscillator is set to OSC1,OSC2 inputs and "HS mode"
    An oscilloscope confirms that the crystal is oscillating with
    a good 25MHz signal.
    Can someone tell me what I'm doing wrong?
    DEFINE OSC 20
    TRISF = %00000000 ' Make all output
    ADCON1 = %11111111 ' Make certain that PortF.1 is digital
    CMCON = %00000000 ' Disable comparator outputs
    Flash:
    PortF.1 = 1
    PAUSE 1000
    PortF.1 = 0
    PAUSE 1000
    GOTO Flash
    Charles Linquist
    ADCON1 = 15
    CMCON  = 7
    Sep 2005
    Campbell, CA
    Problem solved!
    In our lab, we had an old version of MPLAB (7.20) that apparently didn't support the 18F67J60 properly. I upgraded to MPLAB version 8.0 - VOILA! The LED is flashing now.
    Charles Linquist
    Sep 2005
    Campbell, CA
    I should also mention that I use an ICD2 to load code. MPLAB version 7.2 was setting the configuration registers incorrectly.
    Charles Linquist
    first post it was a 66J60, and now 67J60
    it still work even with CMCON=0 ? but yeah.. maybe as long as there's nothing attach to the comparator input... it shouldn't caused any grief.. i'm just a little bit surprised
    EDIT: thanks for the update about ICD2
    Can't imagine Charles using less than 128K.
    So I believe it was a 67J60 all along.
    Sep 2005
    Campbell, CA
    A typo. I'm using an 18F67J60
    And Darrel, you are correct. I'm constantly hammering on Microchip to build a bigger 18F part.
    It seems that I might be getting their attention. Stay tuned!
    Charles Linquist
  1. LCD Showes Some Wrong Letters
    By sbobowski in forum General
    Last Post: - 23rd September 2008, 20:15
  2. Anyone know whats wrong with this code
    By Bonxy in forum Serial
    Last Post: - 9th March 2007, 17:29
  3. ADCIN - AD settings are wrong
    By teverett in forum mel PIC BASIC Pro
    Last Post: - 4th December 2006, 17:32
  4. What am I doing wrong?
    By mankan in forum General
    Last Post: - 23rd June 2006, 20:03
  5. HDD IDE ATA 2 interface problems. code wrong?
    By rastan in forum mel PIC BASIC Pro
    Last Post: - 27th March 2005, 17:01
