2.2v to 5v
Results 1 to 8 of 8
Thread: 2.2v to 5v
    If I may ask, why don't you use the ULN2001 that has no base resistor and a min Hfe of 1000? You can calculate the external resistor if necessary or connect directly to the low voltage output of the PIC you use.
    No additional transistors. Just a resistor, but I think is not necessary anyway.
    Hi everyone,
    Again thanks for the reply and the effort for helping me out. Thanks to Alain for his schematic because I got it to work. To be honest I found out later on that by removing the LED between the I/O and ULN2003A gave me the 5v needed for input to the 2003A which solved my problem... anyways I guess I'm learning new things...
    Thanks all,
    Joe
  1. Generating 5v from 4 batteries
    By BobP in forum Off Topic
    Last Post: - 27th December 2009, 10:46
  2. 6V to 5V
    By Fisher in forum Schematics
    Last Post: - 11th August 2008, 18:31
  3. 5v and 7v on same board - question
    By mark.oswald in forum Schematics
    Last Post: - 29th July 2007, 00:03
  4. One wire serial comms on +5V line
    By MegaADY in forum mel PIC BASIC Pro
    Last Post: - 21st May 2005, 13:49
  5. Replies: 5
    Last Post: - 23rd February 2005, 18:35
