Isolated FET
Results 1 to 3 of 3
Thread: Isolated FET
    Jun 2005
    Wisconsin
    Default Isolated FET
    I'm using a MOSFET for single direction motor speed control via PWM from a PIC. I'm thinking about isolating the power supply that is used for motor control (via the FET) from the supply used for the control electronics (PIC). What I'm unclear about is if the FETs common needs to be tied to the control electronics common. I know with a standard transistor you have to tie commons to one another; however I wasn't sure if that was the case with a MOSFET.
    So tie commons, no isolation?
    Don't tie commons, isolation (expect for PWM from PIC)?
    Apr 2006
    New Hampshire USA
    Smile isolation or no isolation
    Quote Originally Posted by DynamoBen View Post
    Hi Ben,
    The FET and it’s driver pretty much have to have a common connection. The idea is to make the gate a few volts higher than the source. So some connection has to be made to both, to complete the circuit.
    Maybe you could make use of an optocoupler or optoisolater.
    -Adam-
    Jun 2005
    Wisconsin
    Bummy, I guess an opto is the only option for isolation then. Thanks!
  1. Optically Isolated Phase Controlling Circuit
    By dhanush in forum General
    Last Post: - 19th July 2009, 10:06
  2. isolated or not?
    By cphillips82 in forum mel PIC BASIC Pro
    Last Post: - 22nd October 2008, 00:34
  3. Driving a 180ma relay from PIC port
    By Michael in forum mel PIC BASIC Pro
    Last Post: - 10th May 2007, 00:46
  4. isolated 2-Wire bi-directional interface
    By PICtron in forum Off Topic
    Last Post: - 16th February 2005, 18:46
  5. Isolated A/D converter, SPI I/F
    By srob in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2004, 07:18
