Maximun Cable Length for PIC to LCD
Results 1 to 40 of 53
    Ontario Canada
    Hi Darrel. I have installed MPLAB IDE v8.00 Full Release and setup was done as mentioned.
    Now when compiled I get the MPASM window showing the process and then shows 18 errors.
    This goes by very fast and starts green and then goes red. The errors are similar to what I had before. Here are a few. I have omitted the path for each error.
    205 : Found label after column 1. (WritePort)
    205 : Illegal opcode(_Char)
    234 : Illegal opcode(_LCD_DATAUS)
    249 : Found label after column 1.(DelayUS)
    267 : Illegal opcode(LCD_COMMANDUS)
    and many more
    Arrrrgh!
    Sorry to put you thru all this, it shouldn't be that hard.
    I can't really say what's happening from the errors you showed.
    I could probably see what's wrong if you could send the .LST file.
    It'll be too big to post, but you could email it to
    darrel at pbpgroup.com
    It should've worked
    you all must have cringed when i posted my first blinky on bread board. lol mine are true ratsnests. guess it's time to buy some neato jumpers and stop being a disgrace. sniff lol
  1. 16f688 LCD what have I done wrong
  2. Play with LCD on PICDEM
  3. DS1820 Max Cable length ?
    By dccch in forum General
    Last Post: - 24th January 2008, 07:44
  4. Measure cable length with a PIC?
    Last Post: - 15th July 2007, 18:45
  5. Need help with LCD number display.
